Old 01-02-2004, 04:14 PM   #1
valk_ryder
Found a lamp socket that is hot all the time..
These two lamp sockets were hanging down like this when I bought the truck (72 fleetside). There's a hole on each end of the back side of the A/C control and it's pretty obvious that they are for the lamp sockets.
But one of the sockets is hot. Lights off, doors closed, and it is still hot. This can't be right, can it? The other socket only gets voltage when the instrument lights are on and it varies with the dimmer as I would expect.
It's the hot wire I'm wondering about.
Does the A/C control get 2 lamps, one on each end?
Is there any reason this one socket is hot all the time? If it had a lamp in it then the battery would run down.
The wire is gray and comes out of the factory harness.
thanks,
John
valk_ryder is offline   Reply With Quote
Old 01-02-2004, 04:22 PM   #2
rage'nrat638
rage'nrat638's Avatar
check down at the fuse box...for something plugged in to the unfused hot terminal....think it's gray ....should be plugged in to the dash light side.......
the only thing that would make it hot all the time would be there AT THE FUSE BOX
rage'nrat638 is offline   Reply With Quote
Old 01-02-2004, 04:32 PM   #3
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
Mine only has one.
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 01-02-2004, 04:49 PM   #4
70c10
67-72 Addict!
70c10's Avatar
I thought it was only one gray one for the heater/air controls. The other one appears to be tan. Is it?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-02-2004, 05:14 PM   #5
valk_ryder
It's not hot any more...
The mystery wire is gray and the same gage and identical socket as the other one. But it is wrapped in a different part of the harness. It is wrapped with a large gage orange wire.
Looking at the fuse box I found the gray wire and the large orange wire coming together and plugged into a hot terminal on the fuse block as rage'nrat638 said it would be.
Maybe someone tried to add an under-dash courtesy light and didn't quite get it right.
The wiring diagrams and the owners manual also appear to indicate that there is only one lamp for the A/C controls. It sure looks like there are two socket holes in the back of the control.
I still don't know what the extra socket is for but now that it appears it does not belong I can disable it. That must be where the sparks were coming from when I hit a big bump
as always,
thanks for the help,
John
Old 01-02-2004, 05:27 PM   #6
AndrewDT
AndrewDT's Avatar
I think that's the Battery Auto-drain indicator light!
'72 Suburban 4X4
"Save the Earth, kill yourself"
AndrewDT is offline   Reply With Quote
Old 01-02-2004, 06:14 PM   #7
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Maybe it was someones attempt at under dash gauge lights? Be thankful, most wiring problems are nowhere near that easy to solve.........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 01-02-2004, 06:48 PM   #8
rage'nrat638
i'am the man
been all over my truck...geting the reverse lights to work...
they work now
Old 01-02-2004, 06:58 PM   #9
cdowns
cdowns's Avatar
it could be that the light was for the glove box where they'd have a switch that went to ground when the glovebox door opened. i think your orange wire would be for the cig lighter
