Old 07-18-2022, 02:52 PM   #1
Factory Guy
Factory Guy's Avatar
Dash pads?
Does any body know when the shift is styles of dash pads happened? I thought the top one in the photo went to 1979? before shifting to the style on the bottom?
Factory Guy is offline   Reply With Quote
Old 07-18-2022, 03:53 PM   #2
Prong
Re: Dash pads?
1981 was the changeover year.
Prong is offline   Reply With Quote
Old 07-18-2022, 07:55 PM   #3
Factory Guy
Re: Dash pads?
That's kind of what I originally thought. But I was in a bone yard today and saw a round eye with the later dash. So at some point somebody must have changed it to a later dash.
Old 07-18-2022, 08:19 PM   #4
Pontiac1976
Pontiac1976's Avatar
Re: Dash pads?
https://bowtieguy.proboards.com/thre...ce-bezels-fits
This should help you. Firefox browser works best on this sit
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-18-2022, 11:20 PM   #5
Factory Guy
Re: Dash pads?
Nice write up!
Thanks. I had no idea there were so many differences.
