Old 07-22-2022, 01:42 PM   #1
doowopper
major wheel shake out of the blue
i realize that this truck grouping is '67 to '72 but perhaps someone can chime in about my problem. the truck is an '01 silverado 2500. all of a sudden the other day at 50mph the front wheels started shaking badly. i'm talking scary. i checked the tires for tread separation but i couldn't see anything. my daughter said one time she had a similar event on her car and it was an out of balance wheel. anybody have any ideas or suggestions?
TIA,
buddy
doowopper is offline   Reply With Quote
Old 07-22-2022, 02:00 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: major wheel shake out of the blue
Easy stuff first.... are the lug nuts all tight? Check tire balance (maybe switch F--->R and R--->F). Could be worn out suspension or steering components, including a blown shock absorber. Good luck!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-22-2022, 02:26 PM   #3
HotWheelsFan
HotWheelsFan's Avatar
You got mud in your tires...
HotWheelsFan is offline   Reply With Quote
Old 07-22-2022, 02:39 PM   #4
schovil69
It is possible you lost a wheel weight at speed.
schovil69 is offline   Reply With Quote
Old 07-22-2022, 02:58 PM   #5
72c20customcamper
72c20customcamper's Avatar
Hard to see ply separation in tires . The outside may look good but the tire is shot. Not saying this is your problem but if everything else posted doesn’t result in a fix I would have the tires spun balanced if there is a whip in the tire it will be obvious. How old are the tires ?
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-22-2022, 09:33 PM   #6
doowopper
thanks for the suggestions. i inspected the rims and there isn't one weight on either, inside or out. this is my around town beater until i get my '69 back in service so i usually put take offs on it. i'd guess they are a couple years old. i've had a couple car tires over the years that started to separate and it was visible. probably these larger truck tires are stiff enough to hold together better. i'll keep checking.
Old 07-23-2022, 10:40 AM   #7
hatzie
Moderator
hatzie's Avatar
Try getting the offending tire(s) balanced. The tire guys may notice something you didn't.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-31-2022, 08:55 AM   #8
richards72chevy
richards72chevy's Avatar
Check your hub bearings.
richards72chevy is offline   Reply With Quote
Old 08-05-2022, 10:24 PM   #9
doowopper
Mystery solved. Had the tire shop pull the wheels and one tire was separating but it wasn't visible while it was on the truck. Thanks for all the suggestions. Much appreciated.
Old 08-06-2022, 10:50 AM   #10
hatzie
Moderator
hatzie's Avatar
That fits with the sudden appearance of the problem
