01-02-2004, 06:09 PM | #1 |
hei?
I have the origional 402 BB in my truck and want to upgrade my origional distributor to a GM HEI unit . What year distributor do I look for in an Hei unit? Thank you
01-02-2004, 06:43 PM | #2 |
74 and up
01-02-2004, 07:19 PM | #3 |
74-till they went computer controlled..which most had no vacuum advance and an extra plug and wires..at least thats the way it is with small blocks...correct me if i'm wrong guys....
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
01-02-2004, 07:28 PM | #4 |
Beer Power!!!!!!!!!!
You can use the computer controlled distributors as well. Here's the trick: on the 4 wire lead that comes out of the distributor to the computer controller, connect the "A" and "C" wires together with a spilce (sorry, forgot the colors). Works every time.
Rather be fishin' |
01-02-2004, 08:08 PM | #5 |
Watch out for your cornhole !
Dave, keep in mind, a small block and a big block use the same distributor. Never tell the guy at the junkyard you want anything "Big Block" unless you bring your Vaseline. Tell him you want a distributor out of "that old car over there with a small block in it"......Much cheaper that way.
01-02-2004, 10:42 PM | #6 |
Perchjerker, what do you do with the other two wires?
01-02-2004, 10:54 PM | #7 |
You just leave them disconnected.
A to C will make it run.
01-02-2004, 11:09 PM | #8 |
I recently passed up an HEI because of the computer control. Maybe I will try it now. Thanks
01-02-2004, 11:16 PM | #9 |
There are different types of computer control distributors. The type Perchjerker is talking about is the ESC one, or Electronic Spark COntrol, commonly used in early to mid 80s trucks. It looks just like a normal HEI, but it has an extra black 4 wire plug coming out of it. If you lift the cap off, you will see that the module has lots more pins on it.
01-02-2004, 11:22 PM | #10 |
BOWTIE FOREVER
So let me ask this question about hei,whats the difference in the setting for hei and points? They say number 1 on the points distributor needs to point at the 7o'clock and the hei number 1 points at the 5o'clock,So whats the difference?
69 C-10 SHORT FLEET BED 350 4-BOLT/400 turbo upper & lower molding 65 IMPALA 2-DR 283/POWERGLIDE 66 IMPALA 2-DR hopefully 283/350 ~ CAMELTOE ROCKS ~ |
01-03-2004, 01:34 AM | #11 |
its all about the +6 inches
#1 is where ever you put it.
Don't overlook vans for HEI donors. They ran non computer ones longer than cars, and you can pull them out from the drivers seat. (also a good place to find inline 6 engines with HEI) |
