Old 07-22-2022, 04:56 PM   #1
bennylava
bennylava's Avatar
Is there an oil pressure gauge with 60 PSI maximum?
Hi all. I made the mistake of installing an oil pressure gauge that has a 100 psi maximum reading. This means that it always looks like I have no oil pressure. Back when I had the factory 60 psi oil pressure gauge, this wasn't a problem. The gauge would at least read that there was pressure. I'm hoping that someone makes aftermarket gauges that look nicer, but only go to 50 or 60 PSI.
I know you can buy those factory replacements, but it would look out of place as the rest of my gauges are non-factory.
87 5.7L if that helps. Thank you!
bennylava is offline   Reply With Quote
