Old 07-24-2022, 08:39 AM   #1
Phungki
Phungki's Avatar
Rear crossmember
I have a side fill gas tank. Any reason I shouldn’t move the rear crossmember about 4 inches back to make room for it?
Phungki is offline   Reply With Quote
Old 07-24-2022, 09:19 AM   #2
nvrdone
Re: Rear crossmember
First, we have some unknowns here. What year ? What rear suspension - stock, 4 link, trailing arms with air bags etc etc. Are you thinking about moving the crossmember all the way back to the end of the frame rails?
on my '49 I thought about it, but since the frame rails taper - get wider as they go back - I think the cross member would be too short. but you could shim it. also the cross member would block the bumper mounting holes. that may not be an issue if you use a rolled pan. also, if you are using the stock rear springs, that cross member strengthens the frame so that the spring mounts dont flex. just some things to think about. good luck.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 07-24-2022, 12:06 PM   #3
Phungki
Phungki's Avatar
This is my concern. I did notice the that the rear crossmember tied in with the rear spring mount. I need to move it 4” towards the rear in order to get it to fit. Shouldn’t interfere with the bumper but that’s not a major concern. Worried more about it not being directly tied into the spring mounts anymore.
Old 07-24-2022, 08:43 PM   #4
nvrdone
I'd start looking for a different tank. Ive got a side fill under the rear of the bed and didnt move the cross member. I think I got the tank from CPP but I may be wrong. its been a few years.
Old 07-24-2022, 09:18 PM   #5
_Ogre
_Ogre's Avatar
58 TRUK has the bigger rear tank, I moved the rear x-member to accommodate it. I boxed the frame and back of the frame to reinforce everything. It's only been 36,000 miles and 12 years with no problems.
shop air compressor timer
Old 07-25-2022, 06:57 PM   #6
Phungki
Phungki's Avatar
I’ll check their website
Thank you
Old 07-25-2022, 06:58 PM   #7
Phungki
Phungki's Avatar
I’ve been checking out your build. Very nice. My wife loves the yellow
