Old 07-25-2022, 03:53 PM   #1
K25alive
Rear Shock Extender question
Has anyone used a Rear Shock Extender and mounted it to the top shock stud? I installed 4" drop springs in the rear. The shocks Western Chassis supplied are not long enough. They told me I need to use Shock Extenders. But I've only seen those mounted to the axle (bottom) shock mount, typically for flip kits, which would mean even longer travel. The truck is a '77 C10 short/step. If the Shock Extenders can mount to the top (frame) shock stud, that should do the trick. But is that possible?
K25alive is offline   Reply With Quote
Old 07-26-2022, 09:57 AM   #2
SCOTI
SCOTI's Avatar
Re: Rear Shock Extender question
Based on the orientation/style of the mounts being different @ each end, I'd say you can't unless you're fabbing something custom for your solution.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
