07-27-2022, 11:16 AM | #1 |
72 250 6 cyl cam?
Is the stock cam flat tappet hydraulic or full roller hydraulic??
07-27-2022, 11:40 AM | #2 |
Re: 72 250 6 cyl cam?
Flat tappet. I honestly don't know of any roller cam setups. Well at least I didn't when I built mine 3 years ago.
07-27-2022, 12:23 PM | #3 |
yeah I assumed since IIRC 88?? was when GM went to full roller
Given the low zinc content in todays conventional oil, I may add some Rislone zinc additive. Not sure what was used by PO's. Motor has about 116k mi on it but runs quiet as a mouse with that said I used conventional 10-30 in my flat tapped hydraulic 327 motor without issues |
07-27-2022, 03:36 PM | #4 |
For a new cam I would definitely run high zinc oil (Valvoline Racing) plus additive ( I used GM breakin additive or Lucas oil brand) . That is what I do on all mine for breakin. It might be an overkill, but It stinks to loose a cam on break in for a few dollars extra on lubricants. Then I normally end up using the Rotella T4 diesel oil after the initial break in period
07-27-2022, 03:49 PM | #5 |
I use break in oil even on full roller cam motors (Valvoline VR1) on first start and 500 mi
While I have not had issues on motors with just flat tappet hydraulic cams using todays conventional 10-30 oils (read motors that have a good deal of milage on them)....I am going to add zinc additive to conventional oil in the 72 250. Its the original motor, I assume untouched, but todays oils just don't have the zinc content they did pre CAT motors |
07-27-2022, 05:41 PM | #6 | |
Moderator
https://www.12bolt.com/store/p196/Bi...292_Chevy.html Most "stock" flat cams are perfect for street use....just remember the Zinc additive unless you are using Valvoline VR oil....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
