Old 07-30-2022, 08:13 PM   #1
NASTY-LSX
1986 silverado gearbox fitting sizes. I need 6AN. PLEASE HELP!!!
Im doing a LS swap and need to tie in the power steering lines(custom made)
I need to put 6AN fittings in the gear box. I have been told I need 11/16x18 and 5/8x18 fittings. I thought these gear boxes were metric. Do both fittings have a flare with a o ring or just pressure? I dont have any factory lines to go off of. Thanks
NASTY-LSX is offline   Reply With Quote
Old 07-30-2022, 08:23 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 1986 silverado gearbox fitting sizes. I need 6AN. PLEASE HELP!!!
79 and older were standard thread, 5/8 & 11/16..
Then 80 up went metric, 16mm & 18mm
My 81 is all metric with orings
http://67-72chevytrucks.com/vboard/s...d.php?t=620289
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-30-2022, 09:32 PM   #3
NASTY-LSX
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU
