Old 01-02-2004, 10:09 PM   #1
Marty1MC
Front Rotor Replacement 85 K10 4x4
Folks, has anyone replaced the front hub/rotor on a K10 4x4? I have the autolocking hubs and I was told a special tool is required to get the rotor off. I looked through the manual and the only thing that looks like it may require a special tool is the retainer nut for the hub bearing.
Any thoughts???
Thanks,
Marty
85 K10 4x4 - 4.3l 4 speed
Marty1MC is offline   Reply With Quote
Old 01-03-2004, 01:01 AM   #2
Jason Spears
Jason Spears's Avatar
The only "special" tool you require is the wheel bearing nut socket.
It's a bit of work to replace the rotors but a pretty easy job overall.
Goodluck.
Jason Spears is offline   Reply With Quote
Old 01-06-2004, 02:24 PM   #3
Grim Reaper
Make sure that those auto hubs hit the round bin about 30seconds after they are removed from the truck.
Just need the hub nut tool ($15-20 for most parts stores) and a ice pick. Don't need the hub nut tool if your replacing the locking hubs but whens the last time the bearings were serviced? Ot would be worth checking. Pick up a Haynes shop manual when you get the tool. It has the proper way to preload the wheel bearings in there.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
