08-01-2022, 10:04 PM | #1 |
Fuel Filter
HI there
I"m building my truck its a 6.0, i'm going to run the holley EFI Terminator max on it with a 4.80e with a return fuel line.. I"m putting a BTR Truck norris in the truck for now and thinking of maybe turbocharging the truck down the road.. There for i'm thinking of running the Tank sinc GPA-5 High Performance Fuel Pump Module - 340 Liters Per Hour On 1/2 hard line to 8-AN fittings. But i'm having a issues trying to find a Fuel filter that can take 340 litres because most stuff i find is rated at 240 litres. Or do people just run the summit racing ones and call it a day?? |
08-02-2022, 11:59 AM | #2 |
Re: Fuel Filter
aeromotive, holley, magnafuel will have a filter to support that flow. Even if you have to step up to -10 and get some reducer fittings. Won't be cheap but going fast isn't. You doing a terminator or terminator x, what intake and injectors are you going to run?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
08-03-2022, 03:01 AM | #3 |
Re: Fuel Filter
Maybe look into current technology regarding fuel systems. I know the old stuff is still being pushed, there are many advantages to the newer stuff. No return line, lower amperage, no pressure regulator, fuel is not heated, no external filter, longer pump life, etc. I am using a pwm controller and stock ZL1 pump on my LS swap. A link for you https://www.vaporworx.com/
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 08-03-2022 at 03:07 AM. |
08-04-2022, 07:09 AM | #4 |
Re: Fuel Filter
I have an Earls fuel filter that supports something like 1700 lph or maybe more? I run dual 450 lph pumps in my car that is supercharged. The ends have threads for a 12an, so you just buy fittings that reduce it down to 8an.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
08-26-2022, 04:44 PM | #5 |
Re: Fuel Filter
wow thanks and totally all the information i needed for sure
