Old 01-02-2004, 10:53 PM   #1
sixty8chev
The Sauz
sixty8chev's Avatar
Bad Idea
Ok just browsing through the AIM website and came across these things. They look like they're about an inch thick.
Correct me if I'm wrong but I've been told that more than a half in wheel spacer is wrong, this just seems to be taking it to another level, but the couldn't sell em if they weren't DOT approved coud they?
68 lwb 2wd (spread between 3 garages)
72 Burb - Flat Deck
92 Yukon 3" lift - 33's - the new bush pig
01 Sierra - Daily Driver (for now)
sixty8chev is offline   Reply With Quote
Old 01-02-2004, 10:57 PM   #2
70short/step
70short/step's Avatar
It looks like there is 2 pieces there and the front piece is only about a half inch thick. I think the just bolted it to something to show what it looks like once it is bolted up.
70short/step is offline   Reply With Quote
Old 01-02-2004, 11:31 PM   #3
djracer
djracer's Avatar
I wouldn't buy anything from AIM I have heard nothing bad things about them!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-02-2004, 11:41 PM   #4
Randy70C-10
Randy70C-10's Avatar
That looks like a six lug to five lug adapter to me.
Randy70C-10 is offline   Reply With Quote
Old 01-03-2004, 12:19 AM   #5
grnddwn
belly dragger
grnddwn's Avatar
If your using true billet adapters you'll be fine I've seen three inch ones
grnddwn is offline   Reply With Quote
Old 01-03-2004, 01:28 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
They can sell anything they want if it is DOT approved or not. Besides, one sate's DOT may not like what another state permits.
I say stay away from any spacets. Regardless what it is made out of, it will still put stress on the lugnuts holding it.
Leverage is not always our friend.
Old 01-03-2004, 01:34 AM   #7
bigblock73
yeller
bigblock73's Avatar
AIM = SHAME
bigblock73 is offline   Reply With Quote
Old 01-03-2004, 02:59 AM   #8
zenish
ive got aim drop spindles.they seem to work fine.
zenish is offline   Reply With Quote
Old 01-03-2004, 09:00 AM   #9
Frankd
I have been looking for six lug to give lug ada[ters - where is a good place to get them ?
72 c-10
81 c-30
67 c-10 just sittin in the woods)
70 C-10 " " " "
to compleete frames 67, 70 - in woods
2002 toyota tundra.
12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker
Frankd is offline   Reply With Quote
Old 01-03-2004, 01:29 PM   #10
gr8scott51
gr8scott51's Avatar
Don't
IMO adapters = problems. If you want to go to 5 lug, swap out the hubs and axels.
scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 01-03-2004, 01:45 PM   #11
JadeEmperor
Don't use L-AIM products
Those adapters are really that thick. My buddy picked some up from L-AIM had took them off within 2 months. Nervewracking was the term he used. When driving you could feel the warp and unbalance. Discount tire would not give him warranty on his tires because he was using adapters.
As "grnddwn" said, my understanding is that if they are billet you'll be fine but a lot a people have opinions against any adapters/spacers. Longhorn's got it right about the leverage, it's physics. The hub's not design for that added length and pivot pressure point.
If you have to go with adapters, I would look into these guys: http://www.motorsport-tech.com/
They're more expensive then L-AIM but have been fabbin' adapters for a long time and produce applications for racing - L-AIM just mass manufactures product for the heck of it.
Sorry I gave nickels worth instead of two cents.
Jimmie
Modern Vintage Autoworks
- '70 Chevy C10
- '74 Chevy C30 3+3 Dually
- '04 Chevy Colorado
Built, NOT, Bought. If you build it...they will ENVY!
Drive Slow, Scrape Hard, or Take Your Truck and GO HOME!
JadeEmperor is offline   Reply With Quote
Old 01-03-2004, 02:39 PM   #12
SCOTI
SCOTI's Avatar
Billet adapters work just fine & can be up to 4" thick. There is a difference between spacers and adapters though.
Spacers (usually just simple steel or cast) merely slip between the existing hub & wheel mounting surface. They utilize the factory wheel-studs, reducing the amount of threads available (however thick the spacer is) for the lugnuts to grip when the wheels are bolted up. This is why they recommend 1/2" thick spacers as a max. Any more than that, & you have to use longer aftermarket studs (but then the psi strength of the studs becomes an issue).
Adapters are different. Although they also slip between the hub & wheel mount surface, the original studs/lugnuts actually secure the adapter just like a standard wheel. The adapter then has it's own wheel studs, which can either be the same or a different bolt pattern, that the wheel mounts to w/no compromise in the amount of threads used to secure everything.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-03-2004, 02:51 PM   #13
grnddwn
belly dragger
grnddwn's Avatar
I was going to clarify my point but I see SCOTI already did
Old 01-03-2004, 09:50 PM   #14
zenish
that adapter would be great to mount the spare if you had five lugs on one end of your truck and six lugs on the other.
