Old 08-02-2022, 07:45 PM   #1
gmikkels
grab bars
Hello,
Has anyone done grab bars on the A pillar of a 72 k20?
Thanks,
Gene
gmikkels is offline   Reply With Quote
Old 08-03-2022, 07:41 AM   #2
Re: grab bars
I haven't, but I sure thought it was a great idea on the 88-98s. I used to consider mounting something there back when I was 4-wheeling a lot.
Old 08-03-2022, 10:20 AM   #3
jeffahart
jeffahart's Avatar
Re: grab bars
I use these every time I get in the truck. I cut down some off the shelf grabs from a truck stop parts store and put bicycle handle grips on them.
White K20
jeffahart is offline   Reply With Quote
Old 08-03-2022, 10:27 AM   #4
gmikkels
Re: grab bars
That looks awesome
Old 08-03-2022, 05:23 PM   #5
kwmech
Re: grab bars
Attachment 2209083
Info on where you got those, or a link. My dad could use something like that on his Dodge
Old 08-03-2022, 06:03 PM   #6
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: grab bars
I really like those! I always cringe when I see someone use the steering wheel to pull themselves up into a lifted truck...Not Good!
How did you fasten them to the pillar, rivet nuts?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 08-03-2022, 07:23 PM   #7
jeffahart
jeffahart's Avatar
Re: grab bars
Similar to link at bottom of this post. I did it a few years ago. I cut off the flat part about an inch, re-smashed the tube in the vise(to make the handle shorter, else it will protrude out too far) then I drilled two holes instead of one, then bent the flat part to and angle that worked. I cut the hand stops off of mountain bike handle grips and slid them on. the whole thing is a one or two hour operation.
I also use these for overhead, wrapped them in steering wheel tape. They get a lot of use also.
original Peterbilt Handle
Modified handle
Link to similar handle.
https://www.amazon.com/GG-Grand-Gene...90355465&psc=1
White K20
Old 08-03-2022, 07:25 PM   #8
jeffahart
jeffahart's Avatar
Re: grab bars
I used sheet metal screws, largest ones that would fit. I almost never use rivet nuts.
j
White K20
Old 08-03-2022, 07:28 PM   #9
jeffahart
jeffahart's Avatar
Re: grab bars
And on a side note: To be honest, I just put these in as a stop gap. Thought I would eventually find something better. But I ended up really liking them.
j
White K20
Old 08-04-2022, 09:45 AM   #10
fun in dirt
fun in dirt's Avatar
Re: grab bars
I installed these inside the roof above the door with nut-serts.
https://www.grainger.com/product/MON...ated-Y-N-4KZX7
Love them!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 08-04-2022, 10:15 AM   #11
SunSoaked
SunSoaked's Avatar
Re: grab bars
Made my own. One of the best mods I've ever done for my K20.
SunSoaked is offline   Reply With Quote
Old 08-05-2022, 01:19 PM   #12
gmikkels
Re: grab bars
Some great ideas guys,
Thanks for posting
Gene
Old 08-10-2022, 11:28 PM   #13
Zoomad75
K5Camper
Zoomad75's Avatar
Re: grab bars
I used soft Nylon webbing grab handles intended for a Jeep JK Wrangler.
I drilled through the a-pillar and used a large flat strap on the outside to brace the pillar once the handle was bolted in. It is hidden by the door weatherstrip when it's in place.
I also used one on the opposite side a-pillar and a third one where the factory grab handle would be on over the passenger side door opening.
I use the one on the driver side every time I get into the truck.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
