01-03-2004, 12:17 AM | #1 |
Top of the foodchain
MSD Ignition Control Units
Just wondering if one of these could benifit me? I got a built 355 after market everything. I don't really understand what they do. I thought the hei coil does the trick.
http://www.msdignition.com MSD Ignition Control Units More horsepower from complete combustion. MSD ignition controls are the most successful aftermarket ignitions ever made. The multiple spark design has won races and championships in every type of motor sport. MSD ignitions are consistent, reliable, and durable, even under extremely harsh conditions. The results speak for themselves--more power I was thinking the msd 5 its like $90.00 bucks thanks
1970 K-10 4x4 1975 Jeep CJ-5 4x4 1990 Jeep XJ 4x4 Smell the Magic! |
01-03-2004, 12:21 AM | #2 |
MSD 6AL....is the one you want...has the rev. limiter built in..
go with the billet dist.... you can fire a plug in a bucket of oil... i also run the multi-function controll box Last edited by rage'nrat638; 07-12-2007 at 07:09 AM. |
01-03-2004, 12:32 AM | #3 |
multi function controll box .....controller in the cab
01-03-2004, 12:34 AM | #4 |
200 mph speedo....you will need
01-03-2004, 12:49 AM | #5 |
How does it install and what are the benifits????
01-03-2004, 01:02 AM | #6 |
well.....
the msd box....hooks up fairly easy....a few wires to connect... buy your self a billet dizzy to go with it.... benifits..... no more failed gm controll mod's much higher voltage more dizzy timing controll...upper end and bottom end timing use's msd wires...less spark loss the list goes on multi funtion controll box.... launch controll rpm trans brake launch controll rpm start retard controll each cyl timing... the list goes on.... go here check out the toys www.msdignition.com |
