Old 08-06-2022, 02:34 PM   #1
jb3t
Tire Advice for 78 Big 10 with 15” Rally Wheels
The time has come. I need new tires as the current ones, which are probably 30 years old, are worn.
I currently have the stock 235/75 R15s on for all four tires. I am wondering if I should go a smidge taller on the back to jack the back end up a little. I don’t want to mod anything or swap rims.
Any good options out there? I am going to go with white lettering.
jb3t is offline   Reply With Quote
Old 08-06-2022, 03:07 PM   #2
3757chevy
3757chevy's Avatar
Re: Tire Advice for 78 Big 10 with 15” Rally Wheels
255-70 rear and 245-60 front on 15x8 rally
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 08-06-2022, 09:17 PM   #3
kipps
I can't tell from the pics -- is that 2wd or 4wd? If 4wd, don't mismatch the front and rear tires. Even for a 2wd, I don't like the look of mismatched tire sizes.
The rear is easy to lift. Buy a set of longer u-bolts, and install a two-inch block between the axle and the spring. https://www.offroaddesign.com/suspen...ft-blocks.html
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 08-07-2022, 11:14 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
My burb has 255/70 all the way around on factory 8” wheels. They fill out nicely.
Old 08-07-2022, 12:23 PM   #5
Dead Parrot
Another issue with mismatched sizes is what size do you pick for the spare? If you have a road size tire issue, you could wind up with two different sizes on the rear. Not good, especially if you have some kind of limited slip differential.
Dead Parrot is offline   Reply With Quote
Old 08-10-2022, 08:41 AM   #6
SCOTI
SCOTI's Avatar
Utilize a spare that's the same size as the rear tires.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-10-2022, 07:59 PM   #7
3757chevy
3757chevy's Avatar
That's all I did . You just have match the height...But then I never had a flat.
MIKE
