Old 08-07-2022, 07:39 PM   #1
kens65fb
Anyone insulated inside of doors with Dynamat
Has anyone insulated the inside of the doors??
I'm asking not so much for heat reduction, but for some sound deadener.
When I close my doors, it sounds like an empty oil drum.
I was told that just a few pieces of dynamat, placed i a couple of locations, will help.
Will the dynamat possibly interfere with the window operation??
Any responses will be appreciated.
kens65fb is offline   Reply With Quote
Old 08-07-2022, 08:04 PM   #2
TKCR
TKCR's Avatar
Re: Anyone insulated inside of doors with Dynamat
Yes you can add like a 4” square piece, that’s really all you need. Just stick it real good to the inside of the door sheet metal. It will not interfere with the window.
Old 08-07-2022, 09:11 PM   #3
MT65
I have done it many times, personally I cover as much area that is accessible, but I also use an extra adhesive…years ago some came off in the door, it was a nightmare, have had no issues since using the extra adhesive…
MT65 is offline   Reply With Quote
Old 08-08-2022, 10:09 AM   #4
88Stanger
88Stanger's Avatar
Agreed, i have and always will do this. Also, add to roof. I am installing a custom headliner and there will be soundmat there also.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 08-08-2022, 12:29 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
I did a couple of strips to the inside of the outer door skin (above and below the hip line) and then a strip to the inside at the bottom of the inner panel. I have power windows and there is no interference.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-08-2022, 12:52 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Same here did a couple strips, no interference.
Old 08-08-2022, 02:16 PM   #7
theastronaut
theastronaut's Avatar
50% coverage is just as effective as 100% coverage for sound reduction. The butyl rubber backing is dampening the vibrations in the sheetmetal, it only takes 50% coverage to do the job, no need to waste product and add weight with full coverage.
There are other types/sources of sound that Dynamat style products do not help reduce. Sound Deadener Showdown was a good source for products and info on making the interior quiet but they closed and the website is down. You can still access the info posted here-
https://web.archive.org/web/20210609...rshowdown.com/
theastronaut is offline   Reply With Quote
Old 08-08-2022, 08:14 PM   #8
AcampoDave
AcampoDave's Avatar
I did mine with Kilmat. Went like 70% on outer door skins. They say 50% is all you need but I went a bit heavy because I wanted my doors to have a good feel to them when they close. You know, like a luxury car.
AcampoDave is offline   Reply With Quote
