![]() Join Date: Feb 2020
Cowl vent drain pan
I just got my cab back from the media blaster and have some work to do on the drain rail/pan of the popup cowl vent. I've looked around to see if there is after market stamping for this piece but can't find anything. Has anyone seen where you could order it? Otherwise, I'll drill the spot welds out, repair it, and put it back in. It would be nice to remove the old piece and weld in a new one
Re: Cowl vent drain pan
I've never seen it advertised that I know of.
I checked the Filling Station that normally shows most everything that exists AD truck wise as far as reproduction parts go and nada. https://store.fillingstation.com/sho...&searchtype=FT
![]() Join Date: May 2007
they have to make it somewhere because its part of this patch panel, unless its stamped as one piece.
https://www.classicparts.com/1947-53...fo/44%2D210A/#
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
That's what I was thinking as well, but haven't found it online searching. Will try to call a couple of the vendors and see what they say. Thanks for the responses.
