Old 01-03-2004, 01:10 AM   #1
Clancy68
tranny pan ground clearance
i know this probably should be in engine/drivetrain, but my computers says that server is down. heres the question, does anyone with a 4/6 drop know what the ground clearance of the transmission pan is? or what would be even better(becuase i am considering one) the ground clearance of an extra capacity pan? for a th-400 if that makes any difference.
--Scott
Clancy68 is offline   Reply With Quote
Old 01-03-2004, 01:21 AM   #2
rage'nrat638
rage'nrat638's Avatar
only 2"drop but here's a 400 deep pan
rage'nrat638 is offline   Reply With Quote
Old 01-03-2004, 01:24 AM   #3
rage'nrat638
nother
Old 01-03-2004, 01:37 AM   #4
72superBB
72superBB's Avatar
hey rage,
what type of gasket/sealant are you using on that pan?
thanks
Ron
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 01-03-2004, 01:42 AM   #5
rage'nrat638
question asked by 72superBB
liquid avation form a gasket sealer...comes in a little white bottel
with a brush.....kick butt stuff....no silicone in your trans ...
Old 01-03-2004, 10:32 AM   #6
72superBB
72superBB's Avatar
WHere do you get it from? I cannot seem to make that pan stop leaking either. You only used a liquid, no gasket of rubber or cork or anything?
THanks
Ron
1990 Chevy SWB
Old 01-03-2004, 11:12 AM   #7
rage'nrat638
napa sell's it....used the rubber gasket
Old 01-03-2004, 07:45 PM   #8
Clancy68
ok, thanks i thought they hung down a lot lower, so it looks like im Ebay cruising. by the way, looks very nice under there.
--Scott
Old 01-04-2004, 03:20 AM   #9
1972C10
1972C10's Avatar
i get the real thick cork gaskets from tranny shops the ones that parts houses sell suck .. try coatin the gasket with grease before you install it that helps also check all holes for straightness might have to pen them like on an oil pan or valve cover.
Sometimes transmission pan gaskets are the hardest to get to seal.
1972C10 is offline   Reply With Quote
Old 01-04-2004, 03:25 AM   #10
Injected68LS1
Injected68LS1's Avatar
THanks
Ron
If your looking for a great sealer, you should try Honda-Bond. Its absolutley great on everything and it "kind-of" sticks things together and seals like nothing else. It's a silver-grey color so it matches aluminum stuff. It's a little thick and you just brush it on with your finger.
You can also try Yahma-bond. It's close but it's a little thinner.
Not kidding about these. We use them on our race engines for all of the covers. You can get it at the honda dealership.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
