Under Major Construction
does anybody elses truck shake???
does anybody else have this problem? my truck shakes when i slow down, and anytime when im at about 35mph. sometimes it shakes all the time regardless of speed. any help is welcomed
yeller
make sure your tires are balanced properly and are not missing any weights. You can also check your alignment, and/or check for worn out front end components (tie rods, ball joints, etc).
Also, how are your brakes? Maybe you have a wharper rotor, are all lug nuts tight. There could be a million possibilities. Good luck. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 01-03-2004 at 03:13 AM. |
......or an unbalanced driveshaft
80 Chevy K10 350/350turbo 86 Chevy 1/2 ton shorty project truck 79 Chevy 1/2ton 350/350turbo not much to look at... ***Retired*** 97 Chevy C1500 4.3/5 speed.....daily driver |
2 wheel or 4 wheel??
Support The Board |
#5 | |
BAD BOW-Silverado XST
Re: does anybody elses truck shake???
![]() Where does shake feel from? Does it come through the steering wheel or does the whole truck shake? Did it just start? Did you recently do a brake job or other suspension work? Rotate the tires? >>>>>>>>> |
My truck was doing exactly what you are describing. I went to my local tire shop, they checked it out and changed the rotors for me, fixed the problem. No more shaking!!!
1987 Chevrolet Silverado 2005 Chevrolet Silverado |
Robert Olson Transport
![]() Join Date: Oct 2002
or a loose or messed up center bearing for the driveshaft
before i got my new wheels/tires put on it only did it while braking, but now the whole truck shakes like someone is beside it pushing on it. it also pulls to the right while shaking
Yeah, I would definitely say a warped rotor.
You get what you pay for
![]() Join Date: Dec 1999
Idler arm.
Mike 1985 Chevy C-10 |
