01-03-2004, 03:45 AM | #1 |
Emissions. 86' GMC, what am i missing?
Ok i figure its getting old me posting about my crappy emissions.
Im just missing a couple things. I got Air Pump...Air Pump Belt and the hose that comes off the air pump at the end of that is a Tee connector. I picked up a a air pump check valve and i got 2 air pipes 1 for each side. what else am i missing? The air check valve has one end that has threads in it and the other end looks like ya use a hose clamp to keep it on. So i think im missing whats between the tee and the air manifolds. Anyone got a checklist of emissions. And dont say order a LMC catalog cause i already did :p Last edited by BladeX; 01-03-2004 at 03:50 AM. |
01-03-2004, 02:26 PM | #2 |
alot of those rubber hose runs back into your fuel canister next to the driver fender....rat
01-03-2004, 02:28 PM | #3 |
hey i got an 87 454 out back, ill give you a pic if you want, they should be very close to the same setup....rat
01-03-2004, 03:33 PM | #4 |
alright.
i know im missing a hose or 2 but im not sure what they are called. |
01-03-2004, 04:19 PM | #5 |
Project92 SWB stepside
Do your manifold have the heat riser tubes??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
01-03-2004, 05:29 PM | #6 |
what engine are we dealing with here? i've got all the emissions stuff that i yanked off of my 305.
01-03-2004, 05:30 PM | #7 |
01-03-2004, 08:27 PM | #8 |
do you have the thermostat housing with the plastic thing with all the small hoses?
01-03-2004, 09:05 PM | #9 |
i think so. if its the saucer lookin thing with like 5 hoses coming off it then yes
and yes im a n00b. lol I got the pump all instaed and the thing blows air. i just dont know what i need to connect the rubber house that has a plastic 3 way tee on the end of it to the Air pipes that are on the exhaust manifolds. Plus i have a air pump check valve not sure where that goes. |
01-05-2004, 02:38 AM | #10 |
Stylin
might pick up a shop manual for your truck
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
