08-17-2022, 01:15 PM | #1 |
Another solution to finding factory wiper blades...
If you want to keep the aluminum finish wiper blade, the trico 13-330 is hard to find local. Get a set of trico rain gaurds, part # 31-130 $10 ea at orileys. They have the black aluminum frames. Bend the outer tab at the end so that you can remove the refill. Do the same on the factory blade and insert the new rubber refill into the old blade and bend the tab back. Now you have access to something local.
08-17-2022, 08:51 PM | #2 |
Re: Another solution to finding factory wiper blades...
Thanks for sharing! Great option for those wanting to keep shiny wiper blades
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-17-2022, 08:52 PM | #3 |
Moderator
Yep, exactly what I did, I did a step by step write up on it here somewhere...
