Old 08-17-2022, 09:23 PM   #1
70STOVEBOLT
70STOVEBOLT's Avatar
WTB f as story 3/8 fuel line
From in-cab tank through floor. Installing EFI and want to use stock lines if possible for cleaner appearance. Shipping would be to 46562.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-18-2022, 08:25 AM   #2
Ironhorse
Ironhorse's Avatar
Re: WTB f as story 3/8 fuel line
Not sure still have them but will check in the parts stash. Lines from a 71 with a 350 V8 engine. Will get back to you later today.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 08-18-2022, 08:27 AM   #3
70STOVEBOLT
Thanks Gary.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-18-2022, 12:07 PM   #4
Ironhorse
Ironhorse's Avatar
Mark, sorry but the line I have from the 71 I parted is the EEC vent line that runs up the corner pillar in the rear of the cab. I do have the in cab 3/8'' line from a 70 3/4t but.....looks as if has been modified at both ends. No flare nut fittings at either end, rubber hose and double screw clamps at both ends. Sorry, not much help here I know but that's best I can do.
Wellington, Ks
Old 08-18-2022, 12:50 PM   #5
70STOVEBOLT
Gary, can you post a pic of the line from the 70? I will probably have to modify it anyway, as I am going to be using it as a return line. Holley specifies that the return line be 3/8 instead of 5/16 on the Sniper.
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-18-2022, 02:21 PM   #6
Ironhorse
Ironhorse's Avatar
Mark, pic of the in-cab line that runs thru the floor from the '70 I have. Measures just right at 24 inches in length, the beaded end is the lower going to the carb, the short upper end leading to the tank is the one that has been modified. Looks like was cut with a tubing cutter, clean cut but not sure how much of the original line was cut off? If you can use it, it is yours for the shipping $$. The rubber floor grommet was rock hard and did not survive the removal process, LMK
Wellington, Ks
Old 08-18-2022, 02:56 PM   #7
70STOVEBOLT
Gary, if the 24" is not including the length after the bends, I will take it.
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-18-2022, 03:13 PM   #8
Ironhorse
Ironhorse's Avatar
Sorry I wasn't really clear Mark, the 24'' is the TOTAL length of the line from the cut end to the factory beaded end. Before I removed the line from the tank which I sold some time ago there was a maybe 4'' length of rubber hose with the double screw clamps being used.
Wellington, Ks
Old 08-18-2022, 03:22 PM   #9
70STOVEBOLT
I will take some measurements tonight and get back to you. Thanks again.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-18-2022, 04:23 PM   #10
70STOVEBOLT
Gary, I will take the line, PM sent
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-19-2022, 01:18 PM   #11
Ironhorse
Ironhorse's Avatar
Mark, fuel line headed your way, have a great weekend.
Wellington, Ks
Old 08-19-2022, 02:12 PM   #12
70STOVEBOLT
Gary, thank you again, have a great weekend!
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-19-2022, 07:58 PM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Another great gesture by a long time board member..... Kudos!
LockDoc
Leon
Old 08-22-2022, 01:59 PM   #14
70STOVEBOLT
Gary, I received the line today. I will test fit it tonight after work and let you know if it works for me. Regardless, thank you again for your generosity, and I will pay it forward when I can.
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-22-2022, 06:12 PM   #15
Ironhorse
Ironhorse's Avatar
Good luck with the fuel line Mark, glad I could help out. Hope it all goes as planned.
Wellington, Ks
