![]() Join Date: Jan 2012
Looking for Original Acorn Cap Nuts from Factory Round Mirrors
I'm looking for a few original acorn cap nuts which were used to attach the original 67-70 round side view mirror heads. I have my originals but they have been painted over so I'm looking for nice originals that are still the original clear zinc finish, also, not rusted or all nicked up by adjustable wrenches.
All of the nuts I've found online are smooth round (no crown) or high crown which is why I'm looking for originals. The nuts are 7/16" with 1/4"-28 (fine) threads. Here's a pic of my original (painted gold) nut and a pic I found online to show one in the condition I'm looking for. |
![]() Join Date: Sep 2007
Re: Looking for Original Acorn Cap Nuts from Factory Round Mirrors
ive seen these at ace/truevalue hardware stores
1967custom |
Thanks. I'll check there too.
Still like to find some originals. |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#5 | |
I've got a box of mirror stuff, do you want me to go through it, should be some nuts in there
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Sure, if you've got some nice originals I'd be interested in them. Mine are nice (no dinged edges) but I'm trying to find unpainted ones. Thanks!
Ok let me look, and see what I find
Bump, still looking for these.
![]() Join Date: Jun 2000
I found these a few weeks ago at Menard’s.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
Side profile. Is this the crown you’re looking for, or is this what’s you’re calling smooth?
That’s what the websites I ran across were referring to as “smooth”. I’m looking for ones with an identical profile to my originals. They seem to be most often called “low crown”. There are also “high crown” versions with a taller, pointier head. Also, hoping to find them with less of a polished look.
#13 |
![]() Join Date: Mar 2015
I likely threw my originals out with the used up mirrors.
I understand you want identical. Will need some measurement. Like total height and depth of the hex and the hex size. If you find too shinny it's easy to dull them down in a shaker or tumbler for shells. I could make you a couple but the finish would be raw steel. Not ideal. Cheers From the mcmaster.com site. |
#14 |
Bump
Still looking for some nice original, unpainted side mirror acorn nuts. |
#15 |
Found some.
1. Off a NOS 3960511 mirror (assume it's correct) 2. Modern Replacement (slightly shorter than other two but has acorn shape instead of smooth rounded top. Shoulder height looks the same as the painted one. I'd imagine GM had multiple sources for this nut over the lifecycle of these trucks) 3. Off my truck (assume it's original but painted) |
