Old 08-22-2022, 02:02 PM   #1
kens65fb
Parking Light / turn signal question?
Does the parking light / turn signal socket, take a 1 or 2 filament bulb?
What is the correct bulb number ?
kens65fb is offline   Reply With Quote
Old 08-22-2022, 03:11 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Parking Light / turn signal question?
It would be 2 as the ground is the plug body and there are 2 wires going to them as indicated on the wiring diagram.
Old 08-22-2022, 07:59 PM   #3
kens65fb
Thanks, I'm still not sure what is going on.
The replacement bulb socket is plastic with 2 wires, one black, and one white.
I don't see any reason to ground the metal housing, as the bulb socket, is plastic
Do the dark blue, and light blue, wires connect to the black and white wires comming from the bulb socket.?
Old 08-22-2022, 08:19 PM   #4
SkinnyG
SkinnyG's Avatar
What's it look like inside?
Two contacts in the bottom would be a park light and a signal light, and use an 1157 bulb or something. The socket holder itself would be metal, and make the ground where it connects.
One contact in the bottom would be signal only, no park light, and the black would be your ground. Use an 1156 bulb I think.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-22-2022, 08:32 PM   #5
kens65fb
I does have two contacts on the inside of the socket.
Do I connect the light blue, and dark blue wires coming from the harness to
the black & white socket wires, and ground the parking light metal housing??
Old 08-22-2022, 08:59 PM   #6
The Rocknrod
Moderator
That is what I would do.
Old 08-23-2022, 09:10 AM   #7
hairball
I believe Skinny G is correct so you may have the wrong socket. It should be metal for the ground with 2 contacts in the bottom and use a 1157 bulb.
hairball is offline   Reply With Quote
Old 08-23-2022, 12:30 PM   #8
kens65fb
PROBLEM SOLVED !!!
The lights work perfectly now
Thanks for all who offered advice on this thread.
