need 3/4ton rear leafs in AZ
hey guys.
I am looking for some stock 3/4 ton 4x4 rear springs in Arizona. Im in North Phoenix. Also, was wondering how to remove the old bolts that are in the spring eyes? It seems like they are rusted to the metal insert in the spring bushing. I can turn them with a big breaker bar but the whole bushing turns with it. Any suggestions |
light em on fire. theyll burn the rubber then theyll fall out. also i have some springs but im all the way in louisiana.
![]() Join Date: Nov 2002
springs
will these work? came off a 2wd.
springs
i have a set of rear 3/4 ton 6 leaf w/ overload springs for sale. took off and put 4" lift springs, im in showlow az right above you on the map. ill give them to you for 100 buck or trade. im looking for a good grill(71 or 2) seatbelts black or green perfer green, steering wheel green i could use a few other things lets trade
67ss, I dont know if those would work. IS there any difference between 4x2 and 4x4 leaf springs?
