08-25-2022, 09:12 AM | #1 |
Where to buy NP205 transfer case shifter and linkage (sm465 trans)?
I am looking for a new process 205 transfer case shifter and shifter linkage from a 1969 to 1972 chevy or GMC 4wd truck. Do any of you know who sells these parts? Thank you.
Robert Gredig |
08-25-2022, 10:12 AM | #2 |
Re: Where to buy NP205 transfer case shifter and linkage (sm465 trans)?
Don't have a NP205 transfer shifter but do have the NP205 transfer linkage listed in the 67-72 parts forum. Will bring it to the top for you and you can check it out.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
08-25-2022, 10:43 AM | #3 |
I don't think you will find new anywhere. Also, you will need to decide the bend in the stick before you pull the trigger on ebay or junkyard or elsewhere. Auto/manual trans and different years have different bend configurations.
Start looking at pics of peoples transfer sticks and how they bend inside the cab. Also a good time to start locating the pivot bolt, look at your adapter to determine thread size. You can consider twin sticks and get all the parts from JB or ORD. https://jb-custom-fabrication.myshop...-stick-shifter https://www.offroaddesign.com/gm-np2...k-shifter.html j
White K20 |
08-26-2022, 08:31 AM | #4 |
All about them K’s
Your best bet is to post up a wtb ad in the parts section for the shifter. Be advised that there are differences in the shifters them selves between 69-70 and 71-72. Below in bare metal is a pretty rare ‘70 only 4speed 205 shifter, next to it in black is a ‘71-72. They use different holes in the floor and different mounting bolts, although the ‘70 can accept the ‘71-‘72 bolt if the plastic busing is removed. Also I’ve got another picture with the ‘70 only, a sqaurebody K30 and another chrome 71-72 showing the differences in them.
I’ve got a stash of 70-72 205 shifters but unfortunately none are for sale at the moment.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 08-26-2022 at 08:49 AM. |
