Old 08-25-2022, 04:03 PM   #1
Zonaman
Zonaman's Avatar
2 Temperature Sending units?
I've always been a little confused about how my small block 350 has 2 temperature sending units- one over the thermostat housing and one driver's side head. I'm currently reading off the Thermostat housing. Is there a best location (using standard factory gauge)? Is there any advantage to adding a second gauge that perhaps reads in degrees F?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 08-25-2022, 04:47 PM   #2
72SB
Re: 2 Temperature Sending units?
If you have a factory gauge (original to the truck) than the sending unit wired to it should be right
Vehicles with just a dash light for temp the sender is typically on intake manifold or sometimes T Stat housing. For a "gauge" it would be head, where temp is more accurate IMHO (generally will read 10 degrees hotter than one on manifold)
72SB is offline   Reply With Quote
Old 08-25-2022, 06:28 PM   #3
leftybass209
leftybass209's Avatar
The heads are the biggest issue if you start to overheat, so I'll never quite understand checking the temp in the thermostat housing or manifold.
leftybass209 is offline   Reply With Quote
Old 08-25-2022, 06:59 PM   #4
dmjlambert
dmjlambert's Avatar
Some people have a sending unit for the gauge in the cab, and another sending unit that turns electric fan at the radiator on and off as needed. That may be why you have 2 sending units. There is probably a threaded hole in each head, so both of the sending units can go in the heads if desired. I have a sending unit on the driver side head for the gauge, and a sending unit on the passenger side head that I have yet to wire up that will go to the TEMP warning light. They are different types of sending units, one gives a variable resistance to ground to work the gauge, and the one for the warning light switches on at 240 +/- 10 degrees.
dmjlambert is offline   Reply With Quote
Old 08-25-2022, 07:01 PM   #5
geezer#99
geezer#99's Avatar
Early 283 had the factory sensor on the intake near to the thermo housing.
1968 was the first year for sensor in head.
geezer#99 is online now   Reply With Quote
Old 08-25-2022, 07:57 PM   #6
dagnabbitt
dagnabbitt's Avatar
I have two thermostat sending units and two gauges. Previous owner, rather than mess with the factory gauges and sending unit, added a second one for under the dash that is a little easier to read (ie it has numbers on it).
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 08-25-2022, 09:51 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ I did this because my in-dash temp gauge was going bug nuts. At some point that will be fixed. I priced a complete dash from Autometer. O.o
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-26-2022, 07:12 AM   #8
MARKDTN
I may be wrong, but the temperature sending unit for gauge (or light) was always in the intake and then the head. There could be a ported vacuum switch in the T-stat housing, but I don't believe the gauge sender was ever there from the factory.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-01-2023, 12:32 PM   #9
Zonaman
Zonaman's Avatar
I meant to follow up on this a while back. So if I want a second guage reading off the head, one with numbers on it, what temperature range should be on the guage and is there one that will work with the existing sender?
