Old 01-03-2004, 02:00 PM   #1
dabeers
fuel pump installation
I've been trying to replace my fuel pump and can't get the push rod to stay up long enough to install the fuel pump. I've tried rubbing grease around the rod, but it still won't stay. Wondered if anybody had any better ideas. Thanks.
'72 Chev 3/4 T Long Box Stepside
dabeers is offline   Reply With Quote
Old 01-03-2004, 02:09 PM   #2
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Theres a short bolt on the front of the engine, remove it and find a longer one and tighten it until it holds the push rod up. It's right in front on the fuel pump side.
Cat Fuzz is offline   Reply With Quote
Old 01-03-2004, 02:10 PM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Just don't forget to put the short bolt back in!
Old 01-03-2004, 02:14 PM   #4
Rooster's 67
Rooster's 67's Avatar
passenger side block on front there are two holesin a vertical pattern if you stick a longer bolt in the upper hole while pushing the rod up the bolt will hold the rod up. DO NOT OVERTIGHTEN the bolt just enough to hold it up.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-03-2004, 04:28 PM   #5
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
All you have to do is put some heavy grease on the rod and it will stay up. Ive seen this quick-fix in magizines before, and ive tried it so i know it works.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-03-2004, 11:29 PM   #6
jhow66
jhow66's Avatar
Also make sure the rod is all the way up by bumping motor over--makes putting the pump on much easier.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-04-2004, 05:18 PM   #7
jorgensensc
jorgensensc's Avatar
I must be lucky, because I never have a problem putting in the fuel pumps. I just put the rod in, put the rod on th lever of the fuel pump, and slide it up until the holes align. Then I start a couple of bolts to hod it in place. I've heard the bolttrick, but I didn't want to push a bolt through where it didn't go and mess up the block.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-05-2004, 01:12 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Actually, that is the only reason for the bolt hole there.
No damage can be done if you just snug the bolt down finger tight...maybe a tick more if needed.
Old 01-05-2004, 02:04 AM   #9
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
i just hold it up with a screw driver then stick the pump lever in under the rod and then pull out the screw driver
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 01-05-2004, 02:11 AM   #10
PR454SS
PR454SS's Avatar
I go with the same theory I just use a small pair of needle nose pliers
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 01-05-2004, 06:25 AM   #11
jimfulco
A friend of mine used a bent-up piece of wire.
jimfulco is offline   Reply With Quote
Old 01-06-2004, 01:00 PM   #12
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Mine doesn't have a bolt hole, so my brother-in-law used his finger and quickly got it on there... okay it took him a couple of tries (while he bi@ched and moaned about no bolt hole)... but he got it.
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 01-06-2004, 03:55 PM   #13
Blue Beard
Blue Beard's Avatar
All good ideas.....have to admit never heard of the bolt or using grease.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-06-2004, 04:10 PM   #14
Mudder
Mudder's Avatar
You can use a hacksaw blade also to hold the rod up.
Mudder is offline   Reply With Quote
