08-28-2022, 03:35 PM | #1 |
BlahBlahBlah
Upholstery foam question
Normally I would just PM GOM but thought others may wonder too.
Id like to finish up the bench seat Im putting together while we still have warm weather. Full foam bottom, hounds tooth bench. The bottom foam is in pretty nice condition. It had a smallish crack on the drivers side. I cut it clean on both sides and filled and glued the crack with a thin chunk off another seat foam I had. Ive seen several seats done that the person has put an inch or so thick piece of foam over the stock foam, bottom and back. Seems like a good idea, just wondering what I should be asking for when I figure out where to buy it. I want to find it local not online.
08-29-2022, 08:57 AM | #2 |
Re: Upholstery foam question
On a full foam seat cushion a 1" piece of foam would probably be too much , 1-2 layers of dacron padding should do the job . This shop located in Monroe should have everything you need ,
Monroe Upholstery 220 N, N Woods St, Monroe, WA This video starting at 2:46 in shows how the correct way to install a truck seat cover is done , Invert the cover and lay it on top of the seat and roll the edges over , Flip the seat upside down and start hog ringing the cover on from the back first . https://www.youtube.com/watch?v=JyovOmMkxsE
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-29-2022, 09:48 AM | #3 |
BlahBlahBlah
Ill give them a shot. I was unsure if a shop would sell this and figured Id have to go to a dedicated foam supplier.
08-29-2022, 09:53 AM | #4 |
dacron is used by all furniture repair shops and all fabric supply stores .
08-29-2022, 10:04 AM | #5 |
BlahBlahBlah
We have Joanne Fabrics out here. Ill give them a shot ... Thanks again for being there for us!
04-14-2023, 03:14 PM | #6 | |
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-15-2023, 08:36 AM | #7 |
I followed Grumby’s advice my seat came out great . Bought the poly mat at Joann fabrics
04-15-2023, 10:46 AM | #8 |
That looks great, I am several months away from doing my seat.
