Old 08-29-2022, 02:22 AM   #1
bennylava
bennylava's Avatar
How to test power window voltage and where to supply power?
I'm trying to fix my slow passenger side window in my 87 truck. It's slow going up and down, and it often needs a person to help it go all the way up. I have already replaced the window motor and the regulator with new AC Delco stuff. So we can rule that out.
If anyone knows what all the various colored wires do that connect to the passenger side switch, please let me know. I have the Power Probe (if any of you are familiar with that thing) and it can send power through the end. But I'm not one to go sending power down wires that I don't know where they go. Bad idea.
I searched around and I did find this, but I think it's for an 83 model, but maybe it's the same as 87? Anyway I'm not so good at reading electrical schematics. Looks like the passenger side switch is at the very bottom but I'm not certain where to plug in the volt meter prongs to test the voltage.
http://www.73-87chevytrucks.com/tech...werwindows.gif
bennylava is offline   Reply With Quote
Old 08-29-2022, 09:11 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: How to test power window voltage and where to supply power?
This on the site,: https://67-72chevytrucks.com/vboard/...d.php?t=545416
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-30-2022, 12:51 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
have you tried simply greasing the tacks and the window felts
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-30-2022, 05:39 PM   #4
bennylava
bennylava's Avatar
Yes but unfortunately that had no effect.
If anyone knows, I'd like to know how much voltage drop you're supposed to see when the windows are in operation. My guess is that you don't want to see it drop below 11v when you're pressing the switch. Not sure though.
Anyway if I can determine that maybe I can just fix an electrical problem and avoid having to tear down the whole door and rebuild it.
Old 08-30-2022, 07:07 PM   #5
hatzie
Moderator
hatzie's Avatar
AGS extra fine dry graphite powder in the flocking on the tracks and wet silicone lube like Sil Glyde in the regulator pivot points and rollers.
Slow motors can be from the motor itself. The aromatics in the 40-50 year old grease can outgas leaving heavy grease that doesn't flow into things. You can disassemble the motor from the regulator, clean out the old grease, and re-lube the worm gear.
The motor ground path is through the motor body. This means the ground path travels through your hinges. Adding ground straps between the door and the chassis can beef up the ground.
Unlike modern vehicles that use relays to offload the high current motor from the switches... The stock squarebody switches carry the full motor current load so the contacts get pitted and carry less electrons.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-31-2022, 03:36 AM   #6
bennylava
bennylava's Avatar
I guess white lithium grease is a no go. By flocking do you mean the felt tracks, or the regulator's tracks?
Old 08-31-2022, 06:36 PM   #7
hatzie
Moderator
hatzie's Avatar
The felt tracks.
You can use Lithium in the regulator.
Relays to offload the current from the switches would go a long way. GM used a relay on the power locks but not the windows.
These windows were never speed demons.
Old 09-01-2022, 04:34 AM   #8
bennylava
bennylava's Avatar
I have these two greases. Should I use the one in the tube?
Old 09-01-2022, 10:40 AM   #9
hatzie
Moderator
hatzie's Avatar
Either should work in the regulator mechanism. Grease attracts dirt so don't go overboard with it and don't use it in the felt flocked tracks.
You should be able to get extra fine dry graphite powder from the hardware store where you buy Hillman nuts-n-bolts and get keys cut. Ace, Tru Value, ...
Old 09-01-2022, 04:40 PM   #10
bennylava
bennylava's Avatar
Thanks I'll go looking for the graphite.
I need to determine if my vent window uses 1 piece or two piece window seals. I was hoping you would know. I had mine replaced about 10 years ago, and I can't remember which ones I used. I remember buying them at the Chevy dealer's parts counter. Don't remember anything about 1 piece or two piece.
I don't want to screw up and buy the wrong ones. But I can't be sure it doesn't already have the wrong ones on it. They were so road noisy that I ended up using silicone to seal up the gaps. So I'm afraid I might have the wrong ones.
Thank you
Old 09-03-2022, 02:04 AM   #11
bennylava
bennylava's Avatar
Alright I went ahead and bought both of those things. To clarify, you also use the Sil Glyde in the roller tracks, correct?
Old 09-03-2022, 06:40 AM   #12
TKCR
TKCR's Avatar
Thank you
This video will tell you how to determine what your vent windows you have.
https://youtu.be/9YwM0piQ-OE
Old 09-05-2022, 09:28 AM   #13
hatzie
Moderator
hatzie's Avatar
In and on the rollers.
