Old 01-03-2004, 05:39 PM   #1
charles oliver
68 camtruck
charles oliver's Avatar
Electric Choke Question
I recently aquired this truck and noticed the choke isn't closing. It is an Edelbrock 1406. I grabed a hold of the plastic choke cover to adjust it and noticed it is very hot. The engine has not been started in a few days. I went to remove the wire and it jumped an arc and burnt me a little.
Question, Is the choke fried or what could make this be hot to the touch without the engine running. It is a tan wire on the top connector.
Appreciate any help
Charlie
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 01-03-2004, 06:02 PM   #2
sixbangr
sixbangr's Avatar
it is hooked up wrong. Should only have power when the key is on. It may not be fried , but it may well be.
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 01-03-2004, 06:09 PM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Like "sixbangr" said it should only have 12v when the key is on . There is a "ing unfused" connection on the fuse box in the cab that most of us have used .
I installed a 5 amp fuse inline just as a precaution.
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 01-04-2004, 03:27 AM   #4
1972C10
1972C10's Avatar
check the wire that was connected to it see what it does if it was unfused and something happened to the choke it would have fryed it cause it woudlnt let up givin it 12 volts .. If you have acess to a multimeter put it on the amp posistion run the power trough the meter and see how many amps it pulls.
1972C10 is offline   Reply With Quote
Old 01-04-2004, 05:08 AM   #5
Jerdog
If the choke housing is hot I would say the element is fine. That's how an electric choke works. You just need to get that connected to a switched ignition terminal instead of battery.
Jerdog is offline   Reply With Quote
