Sbc 350 big crack on block under intake
pulled the intake off to replace the gasket and found a nice crack on #3 side. Very small amount of coolant in lifter bay when I pulled intake off. I’m sure I spilled some also. Oil has seemed to be fine. Any cause of how it cracked? Possibly got to cold at some point in its life. Over heated? JB weld her up and see what happens or junk it?
Re: Sbc 350 big crack on block under intake
well if it was mine,i'd be replacing it.that crack is right at the deck,it must've frozen at some point?you certainly don't want antifreeze in the oil,that'll kill bearings for sure,a band-aid might be to J-B Weld it up if you had to get it home but long term,even if you got it stopped up,i'd never trust it?
![]() Join Date: Dec 2013
Junk it , it's not worth the time to even attempt to repair it . And JB weld will do nothing for it . Sometimes things just aren't worth trying to repair . it's done .
![]() They'll be plenty of comments on how someone fixed one with JB weld or using Belzona but repairs like that don't last and may work for awhile on a farm truck or tractor where if it does get worse you'll just have to tow it to the barn , It's not like it's a numbers matching rare engine , And I'd have a hard time driving it anywhere knowing it had an issue that one day may leave you seriously stranded on the side of the road . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Not worth taking chances. I'd junk it. I'm curious what engine it is. Original or?
Freeze damage.
I've seen it many times.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
It’s a 70’s someone put in my 61. I’m thinking freeze damage as well. I’ll be throwing in another 350 I have done here shortly. Canada block. #6 push rod is ready to snap in half as well. Glad I pulled the intake when I did and not out driving with the wife lol.
BLOCK #’s 3970010 V0599800 |
![]() Join Date: Mar 2015
Yes, it is freeze damage. I had a block in the garage one cold winter, without a water pump installed, and it cracked in the same area.
It's junk in my opinion. Let me rephrase that. The amount of effort to install it isn't worth the risk. Yes, it may be possible to fix it. Unless it's a rare block I would start over. Last edited by Accelo; 09-04-2022 at 04:00 PM. |
![]() Join Date: Jan 2002
Yes. Frozen block. In had a similar issue. Went to have the engine rebuilt and magnaflux revealed a crack on both sides in the same area. Signs were there. Oil cap had the tell tale foam. The truck was out of Northern Idaho. Back in those days a 4 bolt main block was only $150.
Amazingly I drove the truck 2 years like that. I don’t recommend doing it . . . I changed the oil enough to prevent the bearings from getting scored. (PS. I have a 2015 Ford Escape sucking antifreeze. Probably a bad head gasket. POS. I put in stop leak. It slowed the loss of antifreeze significantly. I’m still driving it until I can afford a new car.)
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
Active Member
![]() Join Date: Jun 2021
Its a sign of over heating! I just scrapped my 72 blazer block for the same reason..Granted I was rebuilding it any way at the time...
![]() Join Date: Jan 2001
That block isn't junk...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#11 | |
![]() Join Date: Nov 2018
Moderator
![]() Join Date: Jun 2017
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#13 |
#14 |
Very expensive table.
#15 |
![]() Join Date: Mar 2013
As my Dad would say " I can get you going but don't drive any further from the house than you are willing to walk back"
#16 |
I wish i could get out that cheap OTOH Ever price anything Amish built for the home? ![]()
Are you retired too? Nonsense! I'm in my prime |
