01-03-2004, 06:08 PM | #1 |
trailing arm bushings
Has anyone here replaced there trailing arm bushings? I am working on the frame of my 68 and would it all to be new when I put it back together.
01-03-2004, 07:51 PM | #2 |
...i replaced mine with energy suspension polyurathane..kinda of a b#$%^ to get in you'll need a B.F.H.....LOL...
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
01-03-2004, 08:52 PM | #3 |
Replaced mine on my 70 awhile back. Really not that hard to do, but then again I had the bed off.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
01-03-2004, 09:40 PM | #4 |
PROJECT 7DEUCE
Hey nooneye's where did you get your bushing's and what did they cost..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-03-2004, 09:42 PM | #5 |
if you have a large c-clamp a pipe nipple and a piece of flat stock they'll press right out
01-03-2004, 09:49 PM | #6 |
F.A.S.T. president
If you got the arms out of the truck.
Just give them some fire with a torch and they will burn and drop out by them selves |
01-03-2004, 11:17 PM | #7 |
Definitely get some Energy Suspension bushings. When you order these you won't get the outer shells, so when you remove the old ones just leave the shells in the arms. Clean em up real good and install new bushings with plenty of silicone grease (provided with ea. bushing). E.S. poly bushings are a two piece design, which makes them a breeze to install. Now's a good time to replace the arm pivot bolts, I used new grade 8 hardware and torqued to factory specs. Good luck!
-Sam
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
01-04-2004, 03:18 AM | #8 |
I put some energy suspension in my 72 when i tryed to put the first one it it woudnt budge so i put a little wire wheel on my die grinder cleaned the hole out real nice then lubed it back up with that grease they provide with the kit slide right in.
01-04-2004, 03:28 AM | #9 |
All this talk about these bushings makes me want to change mine.
So do they really make much difference???? I don't really notice them being .... bad(old).
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
01-04-2004, 03:50 AM | #10 |
...i dont even remember where i got mine..i think it was thru a local parts store..but i do remember mine were not 2 piece...but i did torch my old ones out and used the B.F.H. to put the new ones in
01-04-2004, 06:18 PM | #11 |
I got all my bushings from autozone it wasnt easy they said they coudlnt get them but they sold stuff made by the energy so i got all the part numbers and had them order them didnt show up in there computer but they were able to order them
01-04-2004, 06:56 PM | #12 |
So..... Do they really make a difference???????????
01-04-2004, 07:26 PM | #13 |
F.A.S.T. president
I dont think you would notice a diffrence between brand new ploys and brand new rubber ones. But if yours are worn out your truck could be dog walking. Or you might feel the rear end is loose.
01-04-2004, 09:20 PM | #14 |
Thanks for the help, I have the arms out so I am going to change them while there out
01-04-2004, 09:48 PM | #15 |
I'm by far no expert on the suspensions on these trucks. But I was under the impression that the rubber bushings alowed the trailing arms to "twist" a little in order for the rear suspension to go through it's entire travel. For example, when you hit a bump only with say the right rear - the motion of the axle housing will cause the trailing arms to move in the same direction (not just up and down, but an actual twisting motion). The rubber bushing gives enough to allow this to happen. When you replace the rubber with poly, wouldn't it reduce the available twisting action of the arms and cause binding when the suspension is trying to work.
I was just curious what your thougts were. I'm going to be replacing at least one trailing arm and will probably replace the bushings at the same time. I didn't even know poly was available... Thanks
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
01-04-2004, 11:33 PM | #16 |
After I Installed Poly Bushings It would Hook Up Alot Better Just Cuts Down On Flex There Still Fairly Soft.
01-04-2004, 11:43 PM | #17 |
its all about the +6 inches
Tom, you have a valad theory there, however, I think these arms flex and twist quite a bit just from the length of the piece. I would like the poly items just for the added life span they offer.
01-05-2004, 01:10 AM | #18 |
Sleep-Deprived
Just want to confirm what others are recommending: re-use your bushing outer shells by just replacing the bushings - because a BFH won't cut it
for installing new bushings WITH the outer shells. I did mine with new GM bushings complete with other shells and a very large vice. A hydraulic press would have been ideal, but the ends of the arms bend easily. Even with the way I did it they wanted to bend. I've replaced bushings before. It's relatively easy with a length of threaded rod and various diameters of pipes, nipples and larger sockets. I wouldn't do it again with bushing with the outer shells though. BTW - Make sure to do the final torque setting with the weight of the vehicle on the suspension & and make sure your arms welds aren't split before you put too much work into them.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It Last edited by 69_hafton; 01-05-2004 at 01:13 AM. |
01-05-2004, 01:23 AM | #19 |
I replaced mine in a relatively short amount of time. I did have the bed off, which I'm sure is a plus. I used a sawzall and cut through the old one, on the tapered side, then knocked both sides out with ease. The new ones went in with a few good raps from the BFH and a socket.
01-05-2004, 11:37 PM | #20 |
bushing replacement
I agree with using fire instead of the BFH. I cooked mine a bit and they get very loose. Seems rubber doesn't like fire. This way the sleeves and arms didn't get damaged. I used the Energy Suspension ones. You guys would be very surprised how strong these arms really are I have braced mine with plates across the 2 front ears and stitch welded them in the rear to stiffen the 2 halves in the area where the u-bolts pass through and they will handle a tremendous amount of HP. I have really abused the heck out of the arms and they hold up just fine. Don't waste your money on the brace kits that they sell from the truck parts places.
Tom |
02-18-2004, 06:38 PM | #21 |
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Sorry for digging up bones…but I have a question. I ordered the Energy Suspension 3.3123 bushing “kit” from O’Reilly’s. I have not seen the package nor have I taken out the old ones out of the arms. From the description the parts guy is giving me it’s only for one arm?? The guy said it was a kit when I ordered it. Can anyone who has purchased this tell me what’s up? I want to get all this stuff back together this weekend and don’t want to hold things up waiting on a stupid bushing. (I need to know if I need to try and find another kit)
02-18-2004, 07:07 PM | #22 |
I bought new GM rubber ones from ECE and pressed the old ones out lubed up the new ones an pressed them in the only hard part was keeping them straight as i pressed them in. If you replace the whole thing you will need to put somthing between the ears so they wont bend and distort.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
02-18-2004, 08:03 PM | #23 |
We torch the old ones out while the new ones are in the freezer and run a wire wheel thru the shell and drop them in. No BFH no problem.
Rest in Peace Ed. Thanks for all the good times. |
02-18-2004, 11:01 PM | #24 |
chevelito
hmm. good ol' science at work. good job mothertrucker
New deadline...when my son can drive. Aloha from Honolulu, HI |
02-19-2004, 03:55 AM | #25 | |
http://www.energysuspension.com/c2wd2.html |
