Old 09-05-2022, 02:36 PM   #1
erick65
1965 C10 Running Board
I’m trying to find a running board, step, or nerf bar that will make it easier to get into my cab. All my searches have turned up is the step used to get into a step side box. Thank you.
erick65 is offline   Reply With Quote
Old 09-05-2022, 05:28 PM   #2
LVPhotos
LVPhotos's Avatar
Re: 1965 C10 Running Board
Your going to have to modify something. How much drop are you looking for? You can get an electric step that folds away. Depending on what you want most mount to cab mounts.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-05-2022, 06:55 PM   #3
erick65
I think your idea about the fold away might just be what I need. I see Lippert has some for RV’s. Not cheap but may best solution. It’s only about 16” from rocker to ground. I’ve been using a 7” step stool. Gets me in just fine but then the stool is on the ground with no way for me to grab it. Embarrassing dilemma.
Old 09-06-2022, 03:28 PM   #4
LVPhotos
LVPhotos's Avatar
A bit of work but this guy made it work
https://youtu.be/h6lTbURwxg8
