Old 09-06-2022, 07:53 PM   #1
kens65fb
Window Cranks and Door Handles Problem
My door handles and window cranks keep loosening and try to fall off every few weeks.
Should I drill an indent into the control shafts, and tighten the screws into the indent, or use some type of locktite on the screws before tightening
kens65fb is offline   Reply With Quote
Old 09-06-2022, 10:14 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Window Cranks and Door Handles Problem
I vote Locktite. A handle falling off when you least expect just sucks epecially for a passenger. You can always put a divot if that doesn't work
AcampoDave is offline   Reply With Quote
Old 09-07-2022, 08:11 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Been working for me, I use it.
Old 09-07-2022, 11:42 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
I did both. I did mark and machine a flat spot with an indentation on the splines and used some blue Loctite for the set screw.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-07-2022, 03:44 PM   #5
forestb
forestb's Avatar
I did both. They also sell set screws with a knurled tip that will give you more friction.
https://www.mcmaster.com/knurled-tip-set-screws/
forestb is offline   Reply With Quote
