Old 01-03-2004, 07:22 PM   #1
jamis
F.A.S.T. president
jamis's Avatar
junk yard treasure or junk?
I picked up a 454 from a junk yard in Miami yesterday. Block casting # 399289 2 bolt with peanut port heads. I has all the front stuff like pulleys, brackets, PS pump and resv. I took it apart today and found a std. size steel crank, +40 forged flat tops wich are junk because it looks like the engine overheated and got hot enough to melt a piece off the #2 piston crown. It has a morroso 8 qt. pan This engine must have not run long after being rebuilt because it had no carbon build up. If anyone is intersted in the stock AC comp. brackets make me an offer I cant pass up.
What do you guys think, was it worth the $500 dollors I payed for it. Just dont tell me you could of sold me one for $300:p
jamis is offline   Reply With Quote
Old 01-03-2004, 08:29 PM   #2
rage'nrat638
rage'nrat638's Avatar
500.00 and it don't run.....DOHOO
rage'nrat638 is offline   Reply With Quote
Old 01-03-2004, 08:43 PM   #3
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Thats a little more than what i would have paid, then again im only 16 and dont have a job!
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-03-2004, 08:44 PM   #4
724x4a/cchevy
You may be able to sell the powersteering pump and resevor and brackets.
My LED Website
I also do LED:
-Third Brake/Cargo
Norwood Survivor
Old 01-03-2004, 08:51 PM   #5
cdowns
cdowns's Avatar
i think $500 is ALOT of money for a blown up engine
Old 01-03-2004, 08:53 PM   #6
Stroker
If it's a rebuildable core then you got a decent deal. Around here 454 cores go for about $500 without any accessories. Hopefully all the cylinders are OK since their already .040 over. Did you have any scuffing in the cylinder with the damaged piston?
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 01-03-2004, 09:00 PM   #7
jcueckert13
jcueckert13's Avatar
as long as the block is rebuildable you didnt do to bad. around here a pos 350 will go for $400
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 01-03-2004, 09:03 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That;s what I paid for mine but it ran and was included in the suburban deal..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-03-2004, 09:18 PM   #9
Rod
Looks like the block has some correct brackets/.. you selling parts of this motor... if so send me a price on the ac brackets if there correct for a short water pump BB. Rod
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-03-2004, 09:41 PM   #10
jamis
F.A.S.T. president
jamis's Avatar
They gave me a 30 day guarentee, if it didnt run just take it back to them. But BB are hard to find around here that havent been used in a marine installation. The big problem with those old marine engines is you will never get all that flaking rust out of the block and you will clog more radiators then you can count. The burnt piston is no big deal to me, I've got some others floating around here some where. I have a complete rotating assembly for a 502 but havent been able to find a block for under $1000 used and then I have to buy heads, brackets and pulleys..blablabla.... before you know it I have a $6,000 engine that will see 1,000 miles a year.
There are at least 50 junk yards in the Miami area, guess how many had a 454 of any year. Just one
Too bad teeitup dosn't live closer to me, he has a stock pile of them.
