My door hinge fix
So I have been screwing with my door alignment for a couple weeks now. The problem I was having is that when the door was closed the top of the door stuck out 1/8 of an inch wider than the cowl. I have taken the door off and on I know at least 50 times. I tried to grind the holes on the hinge on one side so that I could have a little more room to push the top of the door in towards the cab but it wasn’t enough. I have bent and straightened the hinge trying to make it fit that way, finally had enough and cut to the chase. Here’s a picture of where I cut my hinge (top and bottom) then slid the hinge the distance I needed (you really can’t do much more than 1/8 of an inch or you will cause more problems). Re welded the hinge and installed, hinge lines up perfect.
This may not be the right way but I tried everything else with no satisfying results. So if your a little anal like me and can’t just let it go maybe this will help. Some pics for reference. The pic of the door is after, I didn’t get a before pic sorry.
Jan's 53 |
Re: My door hinge fix
Some times you just have to do what you have to do to get the way you want it to be.
The biggest problem for us as enthusiasts with most any old truck is trying to get the fit and finish far better than it was when it rolled out of the factory. I'd say the "Git er done" concept applied far more than the "It has to be right and proper" idea back then .
nice work. you gotta do what you gotta do. curious, without going through your build, was there firewall, a pillar or B pillar work done?
do you have the door weatherstrip applied? sometimes that stuff is quite stiff and can mess with the door fitment, usually the latch end of things. I always advise to set up the door for proper fit before the seals go on. get the softest rubber seal you can I guess. |
#4 | |
No pillar work done No weatherstrip yet Just installed new Altman latches and getting doors fit before paint and assembly.
Jan's 53 |
sounds like you had a good starter cab. how do the door fit the openings? some are good and some are need a lot of help.
![]() Join Date: Sep 2017
Well thought out solution. Glad it worked for you. Good work.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
![]() Join Date: May 2007
great fix!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
looking good!
My build a 49 5 window ls1 4l60e on a TCI chassis http://67-72chevytrucks.com/vboard/s...d.php?t=754926 My travel blog The Wong Winding Road-Adventures of The Chinese Cowboy https://thewongwindingroad.blogspot.com/ |
