09-13-2022, 08:14 AM | #1 |
Headbolt heater removal?
My 67 250 6 cylinder has a Freeman head bolt engine heater installed, that I would like to remove.
I assume it was put in by removing 1 bolt and installing the heater. Would I be ok removing it and replacing it with a head bolt as long as I torqued it ? |
09-13-2022, 08:24 AM | #2 |
Re: Headbolt heater removal?
should be fine
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
09-13-2022, 09:16 AM | #3 |
Who Changed This?
Never heard of it. It should be OK, as mentioned.
An interesting read- http://plainshumanities.unl.edu/ency...oc/egp.ind.027
09-13-2022, 10:24 AM | #4 |
Very interesting... do you have a picture?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-13-2022, 10:34 AM | #5 |
Yes interesting, would like to see what they did to pass thru the valve cover. I've heard of the heated oil dip stick, but not a head bolt.
09-13-2022, 10:36 AM | #6 | |
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
09-13-2022, 12:03 PM | #7 |
Who Changed This?
That link I posted to its history only shows a flathead engine application. It would be interesting to see how it was done on an OHV engine with all the head bolts inside the valve cover.
Tags |
head bolt heater |
