Old 09-14-2022, 07:29 PM   #1
tim71
tim71's Avatar
WTB- K truck or Blazer Speedometer Calibration Box
Want to buy the calibration device that screws on to the transfer case which then accepts the speedo cable. The Blazer that I'm rebuilding was missing this device.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 09-14-2022, 07:50 PM   #2
Accelo
Accelo's Avatar
Re: WTB- K truck or Blazer Speedometer Calibration Box
I have one. $50 includes shipping. The ratios are all different. I am assuming you need the box with the gears and don't care about the ratio? Or If you do know your ratio let me know as i have two of them and can provide the box with the closest ratio. I will post pictures if you are interested. Not all transfer-cases needed the converting box. Only if the possible gear ratio was off more than like 3-4% did GM include the box.
I can help you figure out the ratio if needed. I would need the indicated speedometer reading at the real 60mph speed. You can down load an speedometer app for your phone to get the truck to 60mph.
If it's not running you will need the following information;
1-Tire size, or better year the revolutions per mile.
2-Differential ratio
3 gears in the transfer-case that drive the speedometer (driven and drive gears).
Accelo is offline   Reply With Quote
Old 09-15-2022, 09:32 AM   #3
tim71
tim71's Avatar
Sent you a PM
Old 09-15-2022, 12:00 PM   #4
tim71
tim71's Avatar
WTB cancelled, no longer in need. Thanks, Tim
Old 09-27-2022, 08:12 PM   #5
Louisvillekytruck
Great information
Louisvillekytruck is offline   Reply With Quote
