Old 01-03-2004, 08:56 PM   #1
paintpyro
paintpyro's Avatar
auto crossmember
Does anybody know what size bolts to use for motor mounts and an automatic crossmember? Im changin from the 6 cylinder spot to the 8.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 01-03-2004, 10:40 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I used 3/8x1 inch bolts on my crossmember. That's what it came with stock, so that's what I replaced them with.
Old 01-04-2004, 03:10 AM   #3
1972C10
1972C10's Avatar
Just make sure to get good grade 8 hardware and get castelated nuts those are nuts that have three indentions in them to keep them from backin off kinda like them plastic lined locknuts but work alot better.
1972C10 is offline   Reply With Quote
Old 01-04-2004, 08:56 AM   #4
Tx Firefighter
A castellated nut is one that has notches cut out of it for a cotter pin to go through. They look like a castle is why they are called that.
There are 2 kinds of self locking nuts:
-nylon type- has a nylon ring inside of the nut to keep it from turning easily. To be used in any application subjected to up to 250 degrees F heat.
-hi temp self locking nut- has the indentions in the nut to act against the threads. To be used wherever a nylon lock nut would fail do to being subjected to heat.
A castellated nut is not a self locking nut. It is built to work in concert with a cotter pin for securing it against loosening.
Old 01-04-2004, 10:04 AM   #5
rage'nrat638
rage'nrat638's Avatar
o boy
rage'nrat638 is offline   Reply With Quote
Old 01-04-2004, 01:39 PM   #6
junkyardjohn
junkyardjohn's Avatar
GEE WHIZ TX. HERE YOU GO GIVING CORRECT ADVICE AGAIN WHILE SOMEONE ELSE IS GIVING FREE ADVICE.
BACK ON THE FARM WE ALWAY CALLED CASTRATED NUTS .......
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-04-2004, 02:14 PM   #7
jhow66
jhow66's Avatar
Why not jusy use a lock washer like factory did?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-04-2004, 02:22 PM   #8
junkyardjohn
I'VE NEVER HAD ONE COME LOOSE EITHER, & I USE LOCKWASHERS. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-04-2004, 06:22 PM   #9
1972C10
1972C10's Avatar
Hmm Local parts house referrs to them as castleated.. Then hi temp self locking..
I was just suggesting that so it doest back off.. Seems all the newer models use them on the engine stands
Old 01-04-2004, 06:40 PM   #10
jamis
F.A.S.T. president
jamis's Avatar
Ode to a Castellated Nut
A Poem
by Gregg G Guydish
© 2002
I gaze upon your steely walls,
That hold your keep secure,
Hexagonal battlements,
That protect which you hold dear.
Bind that stud close to your heart,
Safe within your keep,
A holey task you must preserve,
For to lose it is to weep.
But man is stronger than mere bands of iron,
And he pries your merlons free,
There to wrest you from your grasp,
Ignorant of your quiet plea.
Though your defenses have been breached,
And your ramparts so assailed,
You will resume your silent task,
Or my steering will be failed.
Spun again onto your home,
Lo these twenty years past,
I torque you up nice and tight,
So continue, you may be, to last.
As I cinch you down to your prescribed FLB,
And align your crenels with your hole,
I ponder the battles your walls have seen,
Time, and elements, that scathe along your boll.
Here beneath my merry chariot,
You labor valiantly to hold,
Against the onslaught of nature and earth,
Persevering through the heat and cold.
But just to be certain that you do not fail,
I slip in the pin and so it arose,
Then bent it over and secured it,
With a bang across your nose.
jamis is offline   Reply With Quote
Old 01-04-2004, 09:11 PM   #11
68C10
WOW ... I'm impressed. How about a carburetor poem?
68C10
1968 C10 SWB No Options but 40K original miles
1967 K20 LWB 283 4-speed
South Plainfield, NJ
68C10 is offline   Reply With Quote
Old 01-04-2004, 09:32 PM   #12
junkyardjohn
WOW !!! PRETTY NEAT POEM.
I HAVE A HARD ENOUGH TIME REMEMBERING A SIMPLE LIMERIC WITH THE WORD NANTUCKIT IN IT JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-04-2004, 09:36 PM   #13
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Impossible. Nothing rhymes with carberator.
Cat Fuzz is offline   Reply With Quote
Old 01-04-2004, 10:35 PM   #14
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
i don't think poems have to rhyme???
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 01-04-2004, 10:44 PM   #15
jamis
F.A.S.T. president
jamis's Avatar
Q-jet or holley
Old 01-04-2004, 11:00 PM   #16
NGN
NGN's Avatar
Hey TX, Just wondering, Those two self locking nuts. ( nylon type - hi temp ) Can they be used more than once ?
Nick
N.J.
NGN is offline   Reply With Quote
Old 01-04-2004, 11:19 PM   #17
jamis
F.A.S.T. president
jamis's Avatar
Tweak the Holy Holley
Carburator is my name.
But what is my game?
If you know not a Holley
Then you know not my fame.
We are very small and stubby
with a funky yellow body
I travel to and fro work,
By providing fuel to your head.
Ricers, little do you know me
Because your motors are so fugly
That it is truly we that make the power
But what would you know of me
you drive a gay toyota camry
They ask, What is to become of me?
An answer for them I have not,
For you alone can save the holleys.
BUY AMERICAN AND SAVE OUR HOLLEY
Old 01-04-2004, 11:46 PM   #18
junkyardjohn
WOW!!! NOW THERES A TALENT THAT WOULD MAKE GREASE MONKY CHICKS MELT IN THEY'RE OVERALLS. JOHN
junkyardjohn
DON'T RENT U-HAUL
