![]() ![]() Join Date: Jan 2002
Ball joint sleeve 4x4
How far does the upper ball joint go in on front axle.
![]() ![]() 1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
![]() Join Date: Feb 2000
Re: Ball joint sleeve 4x4
It doesn't go in a certain depth. You need to install the knuckle with new balljoints first, torque the bottom ball joint nut to spec, then you thread the adjusting sleeve down and torque that to spec on the upper ball joint and then install the upper ball joint nut. This is a snap shot from the Moog installation instructions.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Ok thanks I thought I had to put it in first at 70 which doesn't work.
![]() Join Date: Mar 2003
My Spicer book says 50 on the castle nut. Then 95-100 on the top nut while lining up the cotter pin slot
Heres the procedure from the 1971 truck service manual.
Lower balljoint nut to 70 ftlbs adjusting sleeve to 50 ft lbs Upper balljoint nut to 100 ft lbs- apply additional torque to align cotter pin hole
