Engine ground strap
I have a 77 C10 that I’m pretty sure is virgin and unmolested. I noticed in the factory wiring diagram it shows what is supposed to be an “11 gage ground strap engine to body ground” connected somewhere toward the rear of the drivers side of the engine. Does anyone have a photo of how this is connected from the factory? Mine clearly has nothing back there resembling a ground strap. Everything on the truck works normal.
![]() Join Date: Feb 2000
Re: Engine ground strap
Typically there is a ground strap from the rear valve cover bolt to the cab firewall, I've also seen them attached to the rear of the LH cylinder head. I don't have a picture handy right now to share. Usually they get forgotten when pulling the engine and get torn off too.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
From what I’ve found on here, the previous Gen trucks (67-72’s) had holes drilled on each side of the middle of the firewall (where the transmission tunnel area starts to form) and ground straps coming from both valve covers. Can’t find any pics of a 73-87 setup.
Something else I’ve found by researching this, is that Chevelles not equipped with a factory radio apparently didn’t come with the engine to firewall ground straps? Apparently they were to prevent radio interference? This is a factory radio delete truck so maybe there’s some truth to this? I’d still like to add them since the truck now has a radio. If anyone has a pic I’d appreciate it. |
Heres the factory engine to cab ground strap on my '74 K20. Firewall to rear bottom valve cover stud.
#6 | |
More grounds are almost always a good thing. Many weird electrical issues are due to poor or missing grounds. |
![]() Join Date: Oct 2007
A pack Rat climbed up in and around the motor of my 71 and our dog chewed the ground strap nearly off all the while barking at the rat,, when I opened the hood the Rat ran for its life,, When I started the truck it almost did not start because of the ground strap being almost chewed off ,,I found the chewed ground strap and changed it and all was good again ,
When you learn a thing a day you store up smart. |
eric8>Here is a picture of my stone stock 77 Sport(LS9) engine.Note>
Ground Strap from firewall to cylinder head on passenger side. There is no ground strap like this on the drivers side. Larry
![]() Join Date: Dec 2009
Here is Another ground that is often deleted.
That Is the ground strap on the negative battery cable that goes to the radiator core support. At the time the owner is just trying to get it back running. Or that's the only cable available without the ground strap. Or it doesn't matter to the owner that it is not there.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#10 | |
On my 73 Nova, 83C10, and 81 C1500, the ground is firewall to a bell housing bolt.
Is this a low mile engine? Would the alternator and starter be original to the engine?
#13 |
| Bookmarks |
