Old 10-02-2022, 10:12 PM   #1
saddletramp
72 -C10 Suprise
Afternoon Guys I worked on my Hood today removed all the paint and look at what I found under about an inch and a half of bondo a very old repair someone drilled holes and tryed to pull the dent out didn't work to well
saddletramp is offline   Reply With Quote
Old 10-02-2022, 10:26 PM   #2
Getter-Done
Getter-Done's Avatar
Re: 72 -C10 Suprise
Wow
That is a Lot.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 10-04-2022, 07:17 AM   #3
Re: 72 -C10 Suprise
Might not be the most professional way to do a repair, but I'd say it went very well if it lasted and you couldn't tell.
Old 10-04-2022, 08:27 AM   #4
Grumpy old man
Grumpy old man's Avatar
Re: 72 -C10 Suprise
That's the way it was done before Stud guns the holes helped hold all that bondo on . drill holes along the damaged area and use a slide hammer with a screw in tip and pull away
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 10-04-2022, 08:28 AM   #5
saddletramp
Re: 72 -C10 Suprise
Morning your right I've had this truck for 5 years finely I'm getting around to the body work I had no idea that was there it's all good I'm up to the challenge I'll post some pictures of the repair Thanks Saddletramp
Old 10-04-2022, 08:41 AM   #6
72c20customcamper
72c20customcamper's Avatar
Re: 72 -C10 Suprise
We would do it that way back in the day . Most guys would just fill but we would weld up the holes . Body filler oozing through the holes will absorb moisture and cause rust failure.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-05-2022, 08:19 AM   #7
Re: 72 -C10 Suprise
The screw-in slide hammer created "outies" you couldn't flatten since the reason you were using it was no room or access for a dolly. So you couldn't pull the dent as far out, took more bondo.
I have a '68 door I thought was original paint. Now I think it had a car carrier accident when new. I stripped it bare and the area all around the standard mirror mount was filler. The paint was from '68 but not what it left the factory with
Old 10-05-2022, 09:00 AM   #8
72c20customcamper
Re: 72 -C10 Suprise
If you over pull all you need is a Oxyacetylene with a small tip and heat the hole and tap it down with a chisel head body hammer. Quickly cool the area with a wet rag your doing two things relieving the stress and shrinking the metal .
https://youtu.be/1s4Ja1IN_Tw
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-05-2022, 12:04 PM   #9
michael bustamante
michael bustamante's Avatar
Re: 72 -C10 Suprise
come on down to NM i got a great hood for ya!! woth the 18 hour drive!! lol
1967custom
michael bustamante is offline   Reply With Quote
Old 10-05-2022, 12:46 PM   #10
saddletramp
Re: 72 -C10 Suprise
Morning Guys Thanks for the hood offer I've got a spare hood I like working with metal I've got a mig and tig welder I'm going to see what I can do I like the history of these trucks what the did back in the Day here's a better look of the damage Thanks
