better turn radius
I have a 77 front cross member with cpp modular drop spindles on my 62 C10 and I was wondering if there is a way to get a better turn radios without breaking the bank or cutting and bending and welding?
Re: better turn radius
Wide tires, taller tires, and the offset of wheels are reduced turning radius. So when you lowered your truck you may have done one of the following mods too.
Often times drop spindles increase track width. Which again can reduce turning radius. A drift truck I read about. Ground down the spindle stops, used a longer pitman arm off the box, and idler arm. Increase turning angle thus increase turning radius. |
Did the mods make the turn radius wider? Or are you just wondering if it is possible to improve on the OEM turn radius?
#4 | |
I am just trying to get around parking lots better. The difference between the modular cpp drop spindles and the regular drop spindles is they keep the track width around the same as stock. My tires are 275's So they are kind of wide but it is not a vary tall tire. Probably around the same height as stock. |
I noticed your in Burbank. If you wanna meet up to compare it to my rcsb to see how good or bad your doing would be cool.
I have stock front suspension, manual steering, 255/65r16 up front, and 285/65r17 rear. |
Thanks for the offer but I am fairly certain that I am getting close to a stock radius. I am looking to see if there are any eazy mods that I can do to make it tighter than stock.
I've got a 91 V1500 (4x4) and would like to know if there is any way to shorten my turning radius. I read somewhere a long time ago that changing to crossover steering would help a little but I have not been able to verify that.
1983 M35 (bobbed and converted to dump) 1984 M1010 1988 Chevy Suburban (5.7TBI/TH700R4/NP208) 1991 Chevy Suburban (5.7TBI/TH700R4/NP241C) |
67-72 parts collector,…
![]() Join Date: Nov 2002
Can you post some pics of your front suspension.
Especially the centerlink and the tie rods. It’s a very common mistake to install the centerlink wrong. This really affects the way it drives.
Post Whore
![]() ![]() Join Date: May 2015
ballencd.. it being a suburban , its not gonna turn real short anyway
check to see if your hitting the axle stops when you go full left and right turn, with it being a 4wd you dont want to bind up the ujoints in the axles..if your hitting the stops, thats about all your gonna get... if you have a steering stabilizer, make sure your getting full travel with it
For some reason my notifications from 67-72chevytrucks has been going to my junk email box so I have been missing these posts. I'm trying to get my e-mail to work correctly as it was in the past. Meanwhile I will try to get a few pictures and do some looking.
As far as I know the steering is as factory. Here is a picture of the tie rod.
It didn't take the first try. See if this gets posted.
#13 |
I will need some help to look at the steering stops which I don't have tonight but will try tomorrow. The steering stabilizer has a nice dent in it but I suspect it isn't interfering with the turning radius. I will get it replaced soon.
