Old 10-09-2022, 01:00 PM   #1
scottmitchellrose
pulled my pcv and it dripped gasoline
rebuilt a 69 350 3 years ago with help from an expert. it's bored .060 over, so last one... the power was choppy on acceleration yesterday so I went to set timing and pulled pcv to get to that distributor bolt. it dripped of gasoline mixed in with the oil. panic set in... it has a new Holley 550 on it. any ideas? bad pcv? floats set too high from factory? ring blow by (ughh)?
scottmitchellrose is offline   Reply With Quote
Old 10-09-2022, 01:34 PM   #2
jumpsoffrock
Re: pulled my pcv and it dripped gasoline
What does the oil in the sump look/feel/smell/taste like?
jumpsoffrock is offline   Reply With Quote
Old 10-09-2022, 03:42 PM   #3
HotWheelsFan
HotWheelsFan's Avatar
Gas in oil can be caused from a leaking fuel pump diaphragm. Check oil level to see if overfull and if enough fuel gets into crankcase it can ignite and blow off valve covers with the force just from cranking the engine over. Use caution.
Bob
HotWheelsFan is offline   Reply With Quote
Old 10-10-2022, 08:42 AM   #4
scottmitchellrose
Thanks for the help. Oil was slightly over filled, and dark/ runny when i changed it. I put in a new pcv and changed oil. The float level on the holley seems to be ok - i can't see anything in the clear window so must be below that. Not sure how to check the diaphragm on the fuel pump. It's a new one put in 3 years ago when the engine was rebuilt. It has less than 1,000 miles on it now.
Old 10-10-2022, 09:17 AM   #5
scottmitchellrose
also- a mechanic friend thinks the float on my Holley is stuck. It's less than a year old, BUT I don't use the truck much so perhaps that too. I'll start there.
Old 10-10-2022, 10:43 AM   #6
LNP
Did you check the float settings or just go with how it came? If you didnt you may wanna start there. Mechanical fuel pumps can develop issues and pump gas in the oil pan. If theres gas in the oil you'll need to change it a couple times to get all the gas out. As a guy that was a automotive diaognostic tech for over thirty years one thing I know for sure, new parts fail and some fail right out of the box. Even name brand
Forgot to add the power valve in the carb could be bad and leaking fuel into the intake.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-10-2022, 11:37 AM   #7
scottmitchellrose
aha! I can see better today and the float level in the window looks to be 3/4 to the top. My adjustment is too high (nope- I did NOT adjust it when I put it on).
All of the ideas y'all gave were GREAT. I am so appreciative. I would have never thought to change the oil a few times, either.
I'll adjust the float first this pm and go from there/ see how it does and if all is good, change the oil again this week. I'll keep you posted.
Scott
Old 10-10-2022, 02:48 PM   #8
LNP
Scott
Its best to adjust the float with the sight plug out. All you want is it barely touching the bottom threads. Good luck I hope this solves your issue.
Harley
Old 10-12-2022, 08:43 AM   #9
fdbdw
fdbdw's Avatar
Not to thread jack but I've been following this thread I’m im really curious on a couple things, not questioning anyone I just can’t make the connection on a couple things.
The only 2 ways I can see getting fuel in the oil is either it leaks past the piston rings or the bowls overflow and some how makes its way out the PCV line and into the PCV valve ( I don’t know if that’s even possible). The combustion chambers and the PCV port are the only 2 connections between the carb and motor, outside of possibly a bad manifold seal.
Second, how would a fuel pump, pump gas into the oil pan? Only connection I see there is if the pump pushes fuel out the pump arm and into the pump arm rod chamber and making its way to the cam. Sorry to thread jack but I’m curious and I appreciate the knowledge.
fdbdw is offline   Reply With Quote
Old 10-12-2022, 09:22 AM   #10
LNP
You are correct on how a mechanical fuel pump lets gas into the oil. When a injector sticks open or a carburetor leaks gas into the intake for whatever reason it can wash down one or multiple cylinders which inevidently leads to gas in the oil. Remember two things the piston rings dont 100% seal think of blow by, and they actually dont press against the cylinder wall. They move on a oil film coated with ever stroke of the piston rod assembly. This is how a engine last a long time. The excessive gas not ony washes this fim off it mixes with the oil on the cylinder wall and eventually into the oil pan. Gas being thin it can follow the cross hatch on the cylinder wall and work past the rings this way as well. Its weird I know but after 30 plus years in the automotive repair field I have seem some strange things I will never beable to expalin.
Harley
Old 10-12-2022, 09:22 AM   #11
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The fuel overflows the bowls and runs down the carb throat into the intake manifold and right into the cylinders past the valves. The mechanical pumps have a rubber diaphragm actuated by the pump lever, and the lever actuated by the rod from the cam. When that diaphragm wears out or gets a hole in it, fuel can get pumped directly into the crankcase.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-12-2022, 09:23 AM   #12
fdbdw
fdbdw's Avatar
Awesome, thank you
Old 10-26-2022, 11:00 AM   #13
scottmitchellrose
I adjusted both bowls on the Holley. Also added a fuel pressure gauge- it's around 10!!!! Way too high. I don't see any fuel leaks- but haven't pulled the fuel pump off (engine has less than 1k on it post rebuild- all new parts).
Seems i need a fuel regulator as a start.
Old 10-26-2022, 11:12 AM   #14
scottmitchellrose
it's a new Holley 550 with a braided dual fuel line feeding both bowls. Any recommendations on a regulator? Thanks
Old 10-26-2022, 01:04 PM   #15
LNP
I always use a Holley regulator
Harley
