Old 01-04-2004, 04:06 AM   #1
WB72
Before and After
WB72's Avatar
e - Brake cables
Will I have to buy new cables when I change my 3/4 ton rear end to a 12 bolt?
The cables that are with the 12 bolt are trashed. but the ones on the 3/4 ton have been replaced a few years ago.
In other words, will these parts interchange?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-04-2004, 09:14 AM   #2
JimKshortstep4x4
Talking
The 1/2 ton 12 bolt cables are different from the 3/4 ton brake cables so you will have to get different cables.
You should be able to sell the cables off of the 3/4 ton rear as guys use 3/4 ton axles.
Jim
