Old 01-04-2004, 04:36 AM   #1
orange72350
orange72350's Avatar
NEw Carb Prolbems
I installed an edelbrock 1406 carb on my 350. the engine in the sig. problem is, it ran nice at idle, but under load it runs rough. it has a stumble off idle, and doesnt want to hold an idle when hot. the screws are adjusted about 2 turns out, where they seem to run best. I dunno what the manual says about it, cause that is all greek to me. i really have no idea what goes on. the problem does seem to go away at higher rpms. any suggestions?
thanx
daler
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 01-04-2004, 04:52 AM   #2
Jerdog
If you bought the carb new it came with a manual that gives all the specs. to make it work correctly. Mine only needed minor adjustments to make it run fairly good. To make it run great I changed the needles and the springs under the needles. The manual explained exactly what to look for and how to fix it. In short read the manual its easy.
Jerdog is offline   Reply With Quote
Old 01-04-2004, 05:04 AM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Need to ask some questions.
Did you hook the electric choke to 12 v when the key is turned on ?
Hei or Stock distributer?
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 01-04-2004, 11:59 AM   #4
orange72350
hei.yeah, i hooked it to a key on power source. i looked at the manual, and its all gibberish to me. its damn cinfusing
Old 01-04-2004, 01:00 PM   #5
cdowns
cdowns's Avatar
if you can't understand the manual you might be better off tacing it to a professional and have it done correctly
Old 01-04-2004, 01:53 PM   #6
Jerdog
Orange, do you have an external tach or vacume guage? Or at the very least a really good ear. If so I'll walk you through setting up the idle portion of the carb. Once you get that then you can tackle the other areas
Old 01-04-2004, 02:04 PM   #7
Bill72BB
Bill72BB's Avatar
Hei, OK
Which vacuum port on the carb do you have the vacuum advance hooked up too.
Looking at the carb the Left side is the ported advance ( HEI ) . The Righrt side is non-ported ( Manifold Vacuum all the time )
Both will work if you are on the (Hei) Left side try switching to the other side and see if it makes a difference. Make sure you plug the side you aren't using.l
Also when the engine is Hot is the choke butterfly fully open ?
BILL
Member DUF Club
Old 01-04-2004, 02:10 PM   #8
oldsub86
I have one of those carbs on a Ford 302 and have suffered some difficulties as well. It runs too rich and I assume I may need to change some parts. One suggestion however, is to pull the top and check the float levels. Mine were way off right out of the box. One side was much different than the other.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 01-04-2004, 02:18 PM   #9
jef5150
Inline 69
jef5150's Avatar
http://www.edelbrock.com/automotive/...ubleshoot.html http://www.edelbrock.com/automotive/eps_intro.html
jef5150 is offline   Reply With Quote
Old 01-04-2004, 03:40 PM   #10
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
the easiest and best way i have found is to take it to a pro and have them tune it with their gas analyzer
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
