Old 10-11-2022, 05:30 PM   #1
93M6Formula
Correct engine clamshells for 85 K10 small block truck
Trying to help a buddy out whos trying to put new engine mounts in his truck. The truck is a mutt but the frame is an 85 K10 frame and he has a 383 in it. The old mounts must have been so shot that it didn't matter what clamshells he was using. so now he's trying to put in new stock mounts and absolutely nothing lines up. Mounts are regular stock SBC mount, clamshells are the tall ones that measure 2 3/4" from face (block mount) to centerline of bolt hole. It puts the drivers side way up when the passenger side is bolted in, this is also with the strut spacer behind it. I gave him some shorter clamshells from a 6.5 diesel truck and they were closer but still off, the measure 2 1/4".
Anyone have a clue what could be going wrong? Or if he has the wrong clamshells in general?
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4
1988 GTA Trans AM 305 TPI 700R4
1993 Formula Firebird LT1 T56
1995 GMC K2500 ECLB 6.5L 4L80E
1996 GMC K3500 CCLB LB7 6L90
93M6Formula is offline   Reply With Quote
Old 10-11-2022, 05:38 PM   #2
93M6Formula
Re: Correct engine clamshells for 85 K10 small block truck
This is what he's dealing with.
Old 10-12-2022, 09:35 PM   #3
kwmech
Clam mounts upside down?
Old 10-13-2022, 09:18 PM   #4
Getter-Done
Getter-Done's Avatar
Years ago, I had the same Issue as this.
It was a 2WD / 4WD thing.
Maybe the mounts on the engine are for 2WD?
The early bird gets the worm,
85 Chevy K-20
Old 10-18-2022, 09:29 AM   #5
v30crewcab
v30crewcab's Avatar
the 4wd use a short clamshell, due to the brace bracket that bolts on behind them. the cars used the short clamshell as well.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
