Old 01-04-2004, 08:36 AM   #1
beamers69
Active Member
beamers69's Avatar
Help
I have a 69 SWB that I am working on. I have changed the
bed from stock to one off of 92 Z71. Any suggestions on gas
tank options? I would like to move one out of cab.
Also am changing motor out I have a 350 in it but am replacing
with 350 from the Z71 gonna go to serpintine belt setup, computer, etc. any ideas on mounting computer?
Will probably try and move steering column over from 92 if
I can get it to mount. Feedback is welcomed.
Don
69_67_92 C-10
Drivable/Under Construction
2002 Impala
1999 Toyota 4-runner
beamers69 is offline   Reply With Quote
Old 01-04-2004, 12:12 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You can put the tank in the rear from a blazer and solve you tank issue's... Can't help ya with the rest of the ?'s but it look's like you have a lot of work in front of ya..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
