10-15-2022, 01:12 AM | #1 |
I'm Baaack,.. sorta
It's been a while since I've been here. Our all original 71 C10 was t-boned and totaled on election day. (Guess that was an omen about what was coming down the pike)! Thought I was done, but nooooooo.......
I am acquiring a 1963 C10 with the high torque 230 motor. To start off,...what oil do you guys recommend using? Any other quirks that I might encounter with this motor? Thanks. Jack |
10-16-2022, 08:55 PM | #2 |
Re: I'm Baaack,.. sorta
Man, bummer on the 71, but welcome to the 60-66 side of life. Please post up some pictures of the 63 when you get a chance.
On the oil, whatever flavor of 10-30 would be just fine in that motor. Just make sure you add some zinc. If you want to, you could use some 10-30 diesel oil that has zinc already in it
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
